Old 12-31-2018, 07:04 PM   #21
monto
monto's Avatar
Default Re: Water Temperature Gauge
Don't fight the brazing / welding process.
Can be purchased from Mac's (Ecklers) Model A parts catalog for about $20.
Think you could find same in Bratton's or Tam's as well.
'30 Coupe
monto is offline   Reply With Quote
Old 01-01-2019, 08:14 AM   #22
kenparker
kenparker's Avatar
......or build yo sef one lik dis. ken
kenparker is offline   Reply With Quote
Old 01-01-2019, 11:22 AM   #23
burner31
burner31's Avatar
Stay away from this one, Speedway Part # 91065041 $25
Looks good but only works for about a year, have gone thru two of them...never again.
Keith
Shawnee OK
'31 SW 160-B
Old 01-01-2019, 12:27 PM   #24
30 Closed Cab PU
Thanks for the heads up. I was looking at that one. I like the larger sweep compared to what I presently have
Old 01-01-2019, 12:47 PM   #25
Davew
Davew's Avatar
I have that speedway one and it measures 20 degrees colder than actual.
Davew is offline   Reply With Quote
Old 01-01-2019, 01:21 PM   #26
burner31
burner31's Avatar
Santa brought me this new one, let's hope it works better and lasts longer.
And I like the looks better.
AutoMeter #1837 $51
Keith
Shawnee OK
'31 SW 160-B
Old 01-01-2019, 01:39 PM   #27
30 Closed Cab PU
AutoMeter #1837 $51
I liked that one too, but I am running 6v positive ground. Looking through their site appears they do not make 6v versions.
Old 01-01-2019, 02:07 PM   #28
burner31
burner31's Avatar
It's a mechanical gauge, voltage does not matter.
I too am running 6V pos ground
Keith
Shawnee OK
'31 SW 160-B
Old 01-01-2019, 02:35 PM   #29
California Travieso
Send a message via Yahoo to California Travieso
Originally Posted by AL in NY View Post
Everyone is putting up posts for "James A" about his problem and he hasn't even checked back to see the results. I guess he's real busy.
Al,
Maybe he hasn't, but a lot of people have gotten some useful information from the topic including me.
David Serrano
California Travieso is offline   Reply With Quote
Old 01-01-2019, 04:11 PM   #30
30 Closed Cab PU
You caught my mistake, same time I was looking at temp gauges was also looking at Tachs. Please correct me again if wrong, I believe Auto Meter does not offer 6v Tachs.
Old 01-01-2019, 04:26 PM   #31
The Master Cylinder
The Master Cylinder's Avatar
I'm sorry. Am I missing something. The Auto Meter 1837 sez it has a 12v sending unit included? Summitt Racing also claims it has an electrical sending unit. ($5 cheaper too!)
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 01-01-2019, 04:37 PM   #32
30 Closed Cab PU
Now I am confused too. Perhaps there are 2 types, one mechanical like a meat thermometer, and a 2cd type working off the battery?
Old 01-01-2019, 05:14 PM   #33
The Master Cylinder
Looking at the Auto Meter site, it appears their #1832 in the mechanical gauge. Which makes sense because I have found most mechanical gauges are 270° sweep. https://www.autometer.com/2-water-te...que-beige.html
The Master Cylinder
Old 01-01-2019, 05:34 PM   #34
AL in NY
AL in NY's Avatar
IMO you can't beat Stewart-Warner gauges. May be more expensive, but they last a lifetime.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-01-2019, 06:15 PM   #35
burner31
burner31's Avatar
Oh geez, Oh geez, Oh geez...Santa messed up big time, just opened up the box and it is not mechanical.
This Auto Meter 1837 will not work on the A, back to square one.
I'll have a talk with Santa about this too.
Keith
Shawnee OK
'31 SW 160-B
Old 01-01-2019, 09:40 PM   #36
Chris Haynes
Chris Haynes's Avatar
I am using the Rex-A-Co gauge from Bratton's. I like is period correct look. Personally I don't like flashy new modern looking things in my Model A.
https://www.brattons.com/temperature...-rex-a-co.html
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-01-2019, 10:02 PM   #37
updraught
updraught's Avatar
Some of the sending units won't leave much room for water flow.
https://i.ebayimg.com/images/g/JMkAA...KW/s-l1600.jpg
https://i.ebayimg.com/images/g/zIwAA...RF-/s-l500.jpg
updraught is offline   Reply With Quote
Old 01-02-2019, 09:53 AM   #38
ryanheacox
ryanheacox's Avatar
Never saw much need for a temp gauge but with a new $4000 engine installed it might be worth keeping a closer eye on things. The rex-a-co gauge from brattons looks good, are they reasonably accurate?
Old 01-02-2019, 10:28 AM   #39
30 Closed Cab PU
Temp gauges are very handy when you have a cooling system that is not working well. You can troubleshoot/try things and see if there is improvement.
Old 01-07-2019, 12:24 AM   #40
Drive Shaft Dave
I have heard that the rex aco temp gauge has been problematic in the last few years .
Drive Shaft Dave is offline   Reply With Quote
