09-04-2012, 03:41 PM | #1 |
1932 original wiring
I'm finishing up a 40's era build on a 32 original v-8 chassis (8BA engine) with parts at hand for either 6 volt or 12 volt system. I already have new headlamps/tailamps & are provided with the correct pigtails. An original steering column will be used with the pass through harness. I would like to order the chassis wiring as listed. Headlight harness #18-11647, dash harness #18-14401, cowl lamp crossover wiring #B-14426, & tailight crossover wiring #B-144424 These are Drake part numbers, would appreciate input pros/cons of these items. Am I correct to assume these three units will complete the chassis wiring as required ? I'm aware that the gages /bulbs will need to be addressed if a 12 volt system is used, the engine plug wires & harness will come at a later date. Thanks,Ron
05-20-2013, 04:43 PM | #2 | |
Re: 1932 original wiring
05-20-2013, 06:34 PM | #3 |
Depending on where you locate your ignition coil, the red wire at the end of the 18-14401 harness may not be long enough to reach the coil terminal. The 18-14401 harness was designed to be used with a tubular conduit for it and the spark plug wires on the left side of the intake manifold and a distributor/coil assembly located in lower center of the front of the engine, not one located at the upper right front corner.
05-21-2013, 06:52 AM | #4 |
If you use someone like Tyree Harris, who makes his own harness, you may be able to get it modified to fit while still looking stock.
Short URL: http://smu.gs/14g7eDW |
05-21-2013, 08:51 AM | #5 |
I did the same thing on my roadster a few years ago. I have Reds headers and I found they interfere with switch body attached to the steering box. I bought a bunch of early fabric covered wire and made up a main lighting harness that looked much like the original. The headlight switch is now in the bottom center hole of the repro stainless dash oval. I also used some repro harness sections as well. I used the original speedometer and new Stewart Warner winged gauges (bat &temp). I put the other two gauges(gas&oil) on a small panel on the bottom of the das left side. It all looks like an original car modified in the early fifties........SURPRISE !!!!! That's exactly what I was looking for.
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
05-21-2013, 10:10 AM | #6 |
A man should do what he thinks best! "The Duke" |
05-22-2013, 11:56 AM | #7 | |
05-22-2013, 03:10 PM | #8 |
One bulb duel filament Bakes / Signal. The other bulb taillights separated by a flange in the taillight stock 32 type taillights. Wires to the rear in same loom.
05-22-2013, 04:10 PM | #9 |
05-22-2013, 05:42 PM | #10 |
Yes I used Sacramento Vintage Fords braided wire & loom that comes in many sizes to take as many wires as needed.
05-23-2013, 08:34 AM | #11 | |
Since you have the stock column drop, did you use the steering tube wiring channel? I see a turn signal lever in your dash picture with external wiring, I'm curious how you tied them in to the main harness. I apologize to RB for highjacking his thread. |
05-23-2013, 08:42 AM | #12 |
I bought the kit but would most likely buy the individual pieces if I did it again.
Used the steering column for the horn wire only since I ran a light switch on the dash. Turn signal wires run outside of column to under dash. |
05-23-2013, 12:39 PM | #13 | |
My goal is to do a authentic looking build also and I'm the type of guy who take it all apart and start over if I don't like it. (but I'm getting better). If you could answer a couple of more Q's I'd appreciate it. Where did you mount -The battery? -The cut off sw? -The start relay? -Fuse panel? If you were to do it again (If you're like me). What would you change? |
05-23-2013, 02:34 PM | #14 | |
05-23-2013, 03:39 PM | #15 |
Thanks CT. I like your engine compartment.
10-04-2015, 09:45 AM | #16 |
Thanks, to all who responded & no you didn't high jack the posting solid axle, so no apologies are required as I value all input as a learning experience. My flathead has yet to mate with the chassis & only a brief start up on the engine stand. Ron
10-05-2015, 02:43 PM | #17 |
A wiring piece you might like if switching to a regulated 2 brush 6 or 12 volt generator is the 1941 11A generator wiring harness...I think it (and the 6 cylinder equivalent) are the only production Ford ones that are fully separate from bigger harnesses. They contain only the 3 generator wires and I think the primary ignition lead, and so are a neat conversion part.
10-06-2015, 01:05 AM | #18 |
That is a one wire Alternator in the gen. case. Cut out wires are fake.
10-06-2015, 08:00 AM | #19 |
Keep in mind that there are two different front wiring harnesses for the head lights - depending on whether you have cowl lights or not. I ordered the 18-11647 Drake wiring harness and it was for a standard model without cowl lights - so it was wrong for my car. The Drake website only has the one harness and they don't mention the application - so I found out the hard way. You need the 18-11646 harness if you have cowl lights and NOT the dual-lamp headlights.
I have replaced my entire wiring system with reproduction 1932 stuff . . . everything just plugged in and worked the first time - was very pleased. I did make a few little mods under the dash - to turn my steering column on/off switch into a magneto kill switch - but I can put it back to 'stock' if needed. |
