Old 12-17-2019, 10:05 PM   #1
PatrickTA
Default Pressure check 3rd main. Model B
Hey all
Just looking for a little advice.
I am going to install a 3rd main oil seal In a Model B engine. The instructions say to pressure check the main bearing with oil to 10lbs.
I’m wondering what the best way is to go about that.
Thanks
PatrickTA is offline   Reply With Quote
Old 12-18-2019, 12:18 PM   #2
Jim Brierley
Default Re: Pressure check 3rd main. Model B
I use an old butane tank rigged to put air pressure on top of the oil in the tank and force it into the valve cover. I have full-pressure engines so already have an inlet in the cover. Won't work on a Model A, only on B's.
