Old 07-27-2013, 10:19 PM   #61
G.M.
Default Re: Overheating Flathead
38 do you fill the radiator? And are you losing water? G.M.
www.fordcollector.com
Old 07-28-2013, 07:52 PM   #62
38 Ford Guy
38 Ford Guy's Avatar
Yes I do fill it full but I have a burp tank on it. It does not overflow.
38 Ford Guy is offline   Reply With Quote
Old 07-28-2013, 11:33 PM   #63
Inherited40tudor
My '40 was overheating (on the gauge) and getting the point gap right and advancing the timing made a significant difference!
Inherited40tudor is offline   Reply With Quote
Old 07-29-2013, 08:28 AM   #64
G.M.
A 50 engine has the thermostats in the goose necks. The top hoses on a 50 are smaller in diameter which could restrict the flow. They make goose necks for your engine for the 1 3/4" hoses. G.M.
Old 07-29-2013, 01:04 PM   #65
dp1743
dp1743's Avatar
Mike in Az. Temp gauge on the left side is the dash (elec). Mechanical on the right side reads 170 degrees. Temp on left reads max with new sending unit. It's definately the gauge. I tried the cardboard deflectors and it worked great. No more overheating, although, I believe it probably wasn't really overheating, but, just a bad gauge. Now I can order nice upper and lower deflectors. Thanks everyone for your advice.
dp1743 is offline   Reply With Quote
Old 08-10-2013, 01:38 PM   #66
dp1743
dp1743's Avatar
G.M. I just wanted to thank you for your advice on the Forum. I got two high-flow stats from Bob Shewman and installed temporary deflectors at the radiator (upper & lower). Boy, what a difference. My 40 now runs at 170-180 all day long. Much appreciated your input. Thanks. Dick in MA (dp1743).
