Old 04-07-2013, 01:30 AM   #1
Jordan
Jordan's Avatar
Default direction of thermostat
Today I put in a thermostat and it's just one I had laying around that came with a box of other parts. I was just wondering which end pointed towards the radiator? From what I remember, the probe end pointed towards the radiator and the "cup" end pointed towards the engine.... or at least that's how I installed it. Can someone tell me if I'm right?
Cowtown A's
Jordan is offline   Reply With Quote
Old 04-07-2013, 01:46 AM   #2
Hicktick
Hicktick's Avatar
Default Re: direction of thermostat
I think you put in in wrong .
The round copper thermo - solid end needs to be facing the engine .
Hicktick is offline   Reply With Quote
Old 04-07-2013, 01:52 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Brattons says top hose pointed side up.
Old 04-07-2013, 10:15 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The wax pellet end must face the hot water in the head, as the picture Mike posted shows. I cut off a piece of 2" barbbed plastic fitting to push down the hose to keep the thermostat form sliding up the hose. You want the stat as close to the head as possible. I drilled two 1/8" holes in my stat to make sure the hot water would circulate past the stat to warm it up.
Old 04-07-2013, 10:17 AM   #5
jrapose
jrapose's Avatar
The way a thermostat works is one side has a tiny plunger and a cavity of wax...the wax is formulated to melt at a certain temperature....when the wax melts the plunger is released and the thermostat opens...when the engine is off and cools down the little piston re-sticks into the wax as it gets solid and the whole process starts over...
The wax is always on the hot side of the water...
Joel
Ole auto shop teacher
jrapose is offline   Reply With Quote
Old 04-07-2013, 10:19 AM   #6
jrapose
jrapose's Avatar
Tom and I must have been typing at the same time...
Joel
Old 04-07-2013, 10:26 AM   #7
Jordan
Jordan's Avatar
So this pointed end towards the radiator?
Cowtown A's
Old 04-07-2013, 10:39 AM   #8
Mitch//pa
Yes
Old 04-07-2013, 12:15 PM   #9
Special Coupe Frank
Special Coupe Frank's Avatar
The "Deep-end" of the stat ( you look inside and see the coil-spring ), should face the engine.
The "pointy-end" faces the radiator.
Special Coupe Frank is offline   Reply With Quote
Old 04-07-2013, 12:27 PM   #10
steve s
steve s's Avatar
Maybe this will help
steve s is offline   Reply With Quote
