03-22-2015, 06:16 PM | #1 |
thermostat
I'm in the process of replacing the radiator in my 30 coupe, do most cars use a thermostat? Thanks, Keith
03-22-2015, 06:47 PM | #2 |
Re: thermostat
i use a stat and hold it in place by cutting an old lower hose which fits inside the upper hose... no external visible clamps needed...
03-22-2015, 07:18 PM | #3 |
Re: thermostat
It helped my car a lot. I just slipped it in the upper hose. pressure pushes it to the top and it just stays there.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
03-22-2015, 07:23 PM | #4 |
Re: thermostat
its best to have it closer to the water outlet.....
forgot to add that i usually drill a couple more bleed holes into the thermostat frame |
03-22-2015, 07:39 PM | #5 |
Re: thermostat
I use one. It's especially good on a cold morning. Warms up in a mile or two.
03-22-2015, 09:48 PM | #6 |
Re: thermostat
03-23-2015, 01:21 AM | #7 |
Re: thermostat
I use this nifty little device that I got from Vintage Precision Products. It uses an "off the shelf" thermostat and has the two 1/8" bypass holes built in. Also has ports for a temperature gauge, and a hot water heater if so desired.
Alaskan A's Antique Auto Mushers of Alaska Model A Ford Club of America Model A Restorers Club Antique Automobile Club of America Mullins Owner's Club Last edited by CarlG; 03-23-2015 at 12:30 PM. Reason: Correct info |
03-23-2015, 03:57 AM | #8 |
Re: thermostat
Never use one, and never had an A that had one.
03-23-2015, 08:09 AM | #9 |
Re: thermostat
Keith
It's a good thing to run. I've run one for over thirty years. If you have a good radiator, the engine never gets to the optimum temperature and runs cool. The thermostat makes sure your engine runs at 160 or 180 depending on which one you run. |
03-23-2015, 10:21 AM | #10 | |
Re: thermostat
You "messing" with good engineering!! On Minerva, the 160 stat would flow more water on a cold start, than you could imagine ! From the provided vent hole & "maybe " some from the pressure pushing the valve open slightly" Yo' Dad
03-23-2015, 11:51 AM | #11 | |
Re: thermostat
http://www.vintageprecision.com/prod...ing/index.html |
03-23-2015, 12:41 PM | #12 | |
Re: thermostat
both Tom W and i do the same thing with the extra holes.... you cant argue with that |
03-23-2015, 06:12 PM | #13 |
Re: thermostat
[QUOTE=Mitch//pa;1055696]Yooo Poparooooni,,
both Tom W and i do the same thing with the extra holes.... you cant argue with that[/ I agree with anything you or Tom W say because I know you guys know what you are talking about. Mitch or Tom do you have a picture of a stat that you drilled out for someone like me to see so I do it right. Thanks Tom F.... |
03-23-2015, 06:16 PM | #14 | |
Re: thermostat
[QUOTE=Tom F OHIO;1055884]
just do the same thing 2 more times equal distances apart... |
03-23-2015, 06:19 PM | #15 |
Re: thermostat
03-23-2015, 08:56 PM | #16 |
Re: thermostat
With thet many holes, it's an UN-THERMOSTAT!! May as well put a CROOKEDY stick in the hose. When we were WAY poor, Chief used a LARGE flat washer, to keep the engine & our BUNS WARM!!
Poor Bill W.
03-23-2015, 08:58 PM | #17 |
Re: thermostat
03-23-2015, 10:17 PM | #18 |
Re: thermostat
Agree with Mister B 100%, my '31 ran cool even with in tropical summers. Since putting in a 160 T in a year ago, we run smooth and strong like never before.
03-24-2015, 06:30 AM | #19 |
Re: thermostat
