01-27-2019, 09:35 AM | #1 |
V8-60 front seal leaking
I am getting oil flung from the front pulley of the 37 tinside 60hp in my coupe. Not serious, but it marks its territory wherever I go and I can't visit people with smart clean driveways. How tricky is this going to be to fix?
01-27-2019, 10:03 AM | #2 |
Re: V8-60 front seal leaking
Park it in the street out front. 8^) Jack E/NJ
01-27-2019, 10:20 AM | #3 |
Then it'll get stolen.
01-27-2019, 11:37 AM | #4 |
01-27-2019, 12:52 PM | #5 |
You have to drop the pan, and remove timing cover, and there has to be a slinger there too, the surface on the pulley where the seal rubs has to be smooth --if it is rough or pitted it will wear the seal quick
01-28-2019, 12:48 PM | #6 |
Sal |
01-28-2019, 03:57 PM | #7 |
Use an original asbestos rope seal and soak it in oil for 3 or 4 days first.
If the crank is worn or pitted install a speedi-sleeve. I have NEVER had one leak that way. |
