03-19-2015, 07:32 PM | #1 |
Test Drive
I have searched my manuals and the site and must be missing something so here goes
I have my 29 Coupe up on jack stands and thought I would slowly shift thru the gears a little before actually driving the car. When I try to shift in 1st or reverse it grinds. I do not force it. Comments for help here? tks Mike |
03-19-2015, 09:29 PM | #2 |
Re: Test Drive
Hello i am looking for someone to tell me what adjustments need to be made
It is like when I depress the clutch pedal it is not working sorry for such a poor description |
03-19-2015, 10:05 PM | #3 | |
Re: Test Drive
03-19-2015, 10:10 PM | #4 | |
Re: Test Drive
03-19-2015, 10:12 PM | #5 |
Re: Test Drive
Your Idle speed might be too high.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
03-19-2015, 10:37 PM | #6 |
Re: Test Drive
Bob |
03-19-2015, 10:43 PM | #7 |
Re: Test Drive
Try applying the brakes first, in case the clutch is dragging a little. This will stop the shaft from free wheeling from the oil drag inside the transmission. I am also assuming you have the clutch adjusted correctly and did not bend the disc during the install.
Idle speed must be close to normal, not fast.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
03-19-2015, 11:02 PM | #8 |
Re: Test Drive
You could put the tranny in first gear then start the engine. Then push the clutch in then the brakes to be sure the disc isn't stuck to the flywheel. Also you have to allow enough seconds for the clutch disc to stop spinning before shifting from neutral to first, just like when at a red light.
03-20-2015, 12:57 AM | #9 | |
Re: Test Drive
03-20-2015, 02:26 AM | #10 | |
Re: Test Drive
Riding the clutch is bad practice because you are wearing out the thrust babbit and throw out bearing. I try to watch for the yellow light, then step on the clutch. By the time the light turns green, the input shaft usually has stopped spinning. |
03-20-2015, 02:51 AM | #11 | |
Re: Test Drive
03-20-2015, 09:10 AM | #12 |
Re: Test Drive
03-20-2015, 09:11 PM | #13 |
Re: Test Drive
ok lots of good info!
i have a lot to do tomorrow Thanks guys |
03-21-2015, 08:38 AM | #14 |
Re: Test Drive
What fluid do you have in the transmission??
Paul in CT |
03-21-2015, 09:44 AM | #15 |
Re: Test Drive
Tom is correct on what is spinning and when
