05-25-2015, 02:13 PM | #1 |
Backfire and Die
2 weeks ago: Out for a drive....started some jumps and jerks...a few backfires. I stopped and in a few moments it smoothed out and I got home.
Yesterday: Out for another drive.....started the jumping and backfiring again but more serious....finally died and would not start. I came home on the hook. I pulled the plugs today - they were a little carboned up but not really too dirty; checked the gap and put them back in. So what's next? Did it slip the timing? Maybe a bad carburetor float? What say ye? By the way, this is a '30 coupe. Walt |
05-25-2015, 02:32 PM | #2 |
Re: Backfire and Die
check for the basics spark and fuel. then attack
05-25-2015, 03:04 PM | #3 |
Like Mitch said, check for spark and fuel and let us know which it is. Check to see if the rotor turns. It also makes a difference as to how it was backfiring and quit.
05-25-2015, 03:19 PM | #4 |
Clean the points, carefully, with FINE grit paper & check the gap. This is the most common cause of runnin' piss poor!
Bill W.
05-25-2015, 03:58 PM | #5 |
Same as mentioned above also... (my glitch a few weeks ago)
Bad Fuel... fuel was not old just a bad load in a gas tank. How old is the fuel in your tank? Missed sputtered no power and back fires when pushed a little. |
05-25-2015, 04:35 PM | #6 |
05-25-2015, 04:40 PM | #7 | |
from what i read we are working on an originally equipped model A |
05-25-2015, 04:48 PM | #8 |
how so, hes having engine running problems, ive just gave him a few places to start, should I just told him it cant be fixed and just forget it?
05-25-2015, 04:51 PM | #9 |
a stock ford model A does not have an accelerator pump or a fuel pump. i have had a little to drink today but not that much
05-25-2015, 04:56 PM | #10 |
opps, sorry wrong forum, should have been in the flathead room, haven't drank it 50 years, so I cant use that as an excuse
05-25-2015, 07:49 PM | #11 |
whhheeww u had me worried
05-26-2015, 12:02 AM | #12 |
I read the title.....my first thought was that happens to me too when I have to much fiber! But then he was talking carburetors ..........
Tim Downtown, Ca |
05-26-2015, 05:20 AM | #13 |
If your plugs were black and fuzzy, be sure to scrape out the carbon in the annulus. sp?
If you did, did it run good after you cleaned them. Could try a splash of water on the carb bowl next time it happens. |
05-26-2015, 05:59 AM | #14 |
Nobody mentioned the condenser. Spark 1st, then fuel. If all's well in those 2 departments it might call for digging deeper. Someone said look to see if the rotor turns. Once in a blue moon the distributor pin can shear, but keep it simple 1st.
06-02-2015, 06:47 PM | #15 |
Thanks for your help...had some trouble trying to log in for several days. Meanwhile, buffing up the points, checking the gap, cleaning and checking the plugs AND a condenser seems to have got her going again. Thanks to you all!
