Old 08-14-2020, 07:17 PM   #1
derek costello
Default hubcaps?
How to hold 40s style hubcaps on a modern 15" wheel that doesn't have the nubs
stamped into the wheel to hold the cap on???
derek costello is offline   Reply With Quote
Old 08-14-2020, 09:00 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: hubcaps?
Measure in to see where they are placed and put weld beads on the wheels in 4 places like where the bumps are. Of course, the opening must be large enough to accommodate the diameter of the hubcap, check this before you do anything.
Old 08-14-2020, 09:20 PM   #3
Lanny
Lanny's Avatar
If you can find someone who has a wheel with the 'innie' nubs who
will let you do a lot of measuring, so you get the nubs positioned
exactly where you need them to be, then weld and grind till cap fits.
When you cut the 'outie' nubs off from the newer wheel, you will
need to do some welding and grinding there too.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 08-15-2020, 09:12 AM   #4
CaliforniaBorn36
CaliforniaBorn36's Avatar
What kind of wheel? OEM steelie? Check Vintique Wheels, they have some to fit various models they sell, maybe they would have something that would work.
CaliforniaBorn36 is offline   Reply With Quote
