05-18-2016, 12:38 PM | #1 |
What correct fuel pump rod assemble to use
What fuel pump rod needed 1949-53 Merc engine and vendor to get it--- it looks like it was a 3/8" tube or rod that was in originally before it was taken apart cooked out and part was lost
05-18-2016, 04:45 PM | #2 |
Re: correct fuel pump rod
That depends on the block. The early 8BA blocks did not have a bushing and used a slightly larger diameter fuel push rod. I believe that rod has a "skirt" surrounding it that contacts the block when the rod is at the lowest position. So check for the bushing in the block before you buy a rod. If you can't find anything PM me I think I have a couple.
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
05-19-2016, 09:51 AM | #3 |
Re: What correct fuel pump rod assemble to use
