Old 05-17-2010, 10:57 PM   #1
Kahuna
Kahuna's Avatar
Default Flathead to Jeep trans to Gear Vendors OD
Hi Gang
Been out of town for awhile and like the new forum setup. Here's a picture of the O/D coupled to the transmision. Hope it works well
Jim
Kahuna is offline   Reply With Quote
Old 05-17-2010, 11:13 PM   #2
Mike in AZ
Mike in AZ's Avatar
Default Re: Flathead to Jeep trans to Gear Vendors OD
nice....what is your rear end gearing??...Mike
Mike in AZ is offline   Reply With Quote
Old 05-17-2010, 11:37 PM   #3
Kahuna
Kahuna's Avatar
It's 4.11
With the O/D it'll be 3.2. Should be ok with 29-30" tall tires
Regards
Jim
Old 05-18-2010, 12:16 AM   #4
Russ/40
Russ/40's Avatar
Which jeep tranny did you use?
Old 05-18-2010, 01:41 AM   #5
Kahuna
Kahuna's Avatar
Russ, it's just a T-176 case (CJ-7, 82-87) I think, but has late 67 Ford toploader gears installed.
Old 05-18-2010, 02:46 AM   #6
52merc
52merc's Avatar
gidday mate so do i get this right a jeep trans with a gear vendors o/d on the rear?? i see you got a remote filter hiden away there trev nz
52merc is offline   Reply With Quote
Old 05-18-2010, 12:08 PM   #7
Kahuna
Kahuna's Avatar
Hey trev. How you doing down there. That O/D solenoid I sent a few years ago still working?
Regards
Jim
Old 05-18-2010, 01:46 PM   #8
Flat Ernie
Flat Ernie's Avatar
Nice setup, Jim. Hadn't considered a GV onto a Jeep T176...very interesting.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 05-18-2010, 03:50 PM   #9
52merc
52merc's Avatar
jim its still going strong i owe you big time,,man thats a neat set up you have there,,t5rev
Old 05-18-2010, 08:40 PM   #10
Kahuna
Kahuna's Avatar
Trev, glad to hear that it's still going. You don't owe me a thing.
Jim
Old 05-18-2010, 09:00 PM   #11
deucemac
deucemac's Avatar
If you can use a 3 speed, you can do what I did on my roadster. I used a '75-'77 Pacer, Hornet, or Gremlin 3 speed with overdrive. AMC used Ford transmissions during that time, however Ford didn't offer an overdrive with their full syncro 3 speeds so AMC used the Ford trans and had Laycock (the originator of the gearvendor system) of England adapt their o/d set up. i just took out the side shift items, plugged the shift shaft holes and used a Jeep T-15 top cover. It works great and was able to adapt a gearvendor control without any problem.
deucemac is offline   Reply With Quote
Old 05-18-2010, 09:25 PM   #12
Kahuna
Kahuna's Avatar
Hi Deucemac, you and I spoke on the phone a couple of times. Your car looks great
Jim
Old 05-19-2010, 03:35 AM   #13
Flat Ernie
Flat Ernie's Avatar
That's a great setup. Greatly increases the viability of using a 3-spd by splitting the gears. A non-OD 3-spd has compromise ratios that are far less than optimum...
T5 Tech
