07-13-2015, 11:27 PM | #1 |
Trimming a Repo Steering Wheel
Just purchased a repo steering wheel and all of the USA made ones require some trimming of the mold seam.
Anybody done this? Thoughts, suggestions on the best way. Thanks, Ed |
07-14-2015, 12:11 AM | #2 |
Re: Trimming a Repo Steering Wheel
Sharp hobby knife and sand paper.
07-14-2015, 04:41 AM | #3 |
A potato peeler worked well for me, pretty good control, so it didn't "dig" in, & it did the tight curves well.
Bill W.
07-14-2015, 05:40 AM | #4 |
I received my in shock I had to remove extra mold and sand . I followed the instructions removing extra with razor and using 1200 grit paper it turn out great
07-14-2015, 06:36 AM | #5 |
07-14-2015, 06:41 AM | #6 |
07-14-2015, 06:48 AM | #7 |
In addition to the trimming with a sharp razor - wet sanding was key for me. 600 and 1200. The outer part is easy - but use caution when cutting in where the "spokes" meet the wheel - they were a little tricky.
07-14-2015, 06:56 AM | #8 |
I also finished with the wet sanding with 1200 grit, but with the steering wheel "mounted" on the column and placing towels around the column and car floor. It came out great and there is no remaining evidence of any seams. It took a few hours to completely "finish" the wheel.
07-14-2015, 07:05 AM | #9 | |
A razor blade doesn't work well there, and I think I used a rat tail file to do the sharp inside curves, then sandpaper. |
07-14-2015, 07:15 AM | #10 |
We should expect to trim an offshore repro part but not American made! I would expect a higher standard of workmanship! Wayne
07-14-2015, 07:29 AM | #11 |
07-14-2015, 08:35 AM | #12 | |
BUT, I REALLY do know how to do stained glass! Dad
07-16-2015, 09:08 PM | #13 |
Thanks to all for your great information. I am trying Bill W's potato peeler idea and it seems to be working great.
Thanks again. Ed |
