11-03-2012, 04:54 PM | #1 |
cause of back fire
what would be or could be the cause of a model A to back fire when letting off the gas? Thanks
11-03-2012, 05:05 PM | #2 |
Re: cause of back fire
Might be the carb is running too lean. Does it do this if you open up the GAV 1/2 turn or more?
11-03-2012, 05:38 PM | #3 |
Is it after it's been running for a long period of time?condenser?Also check the points for proper setting.
www.whidbeymodelaclub.com |
11-03-2012, 05:51 PM | #4 |
Intake vacuum leak.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
11-03-2012, 07:03 PM | #5 |
Are you referring to when you are going down the road or when you are shifting gears or coasting down a hill in gear?
Generally, backfiring under no or light load is due to too-lean mixture to support combustion, so unburned fuel is swept out and accumulates in exhaust system. Either too little fuel (open GAV, raise carb float level, check carb jets) or too much air (as in vacuum leak suggested by 30ccpickup). Steve |
11-03-2012, 07:24 PM | #6 |
