Old 02-15-2018, 01:02 AM   #1
1930marie
1930marie's Avatar
Default Cowl Band restoration
Who restores cowl bands to show quality or has original restored ones for sale? Thanks for helping.
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 02-15-2018, 08:48 AM   #2
BadgerA
BadgerA's Avatar
Default Re: Cowl Band restoration
Try Vintage Vehicles in Wautoma, Wi. Restore bands, radiator shells, bumper clamps, etc. Excellent work and often have restored pieces for sale.
N1940 20th Dr, Wautoma, WI 54982 · (920) 787-2656
BadgerA is offline   Reply With Quote
Old 02-15-2018, 12:07 PM   #3
1930marie
1930marie's Avatar
Thank you - I will contact them this morning.
Michael
Old 02-15-2018, 12:51 PM   #4
macdonge
macdonge's Avatar
While on the topic, any words of wisdom on how to remove/reinstall the cowl band without damaging it in the process. Mine (on a 1930 Roadster) will have to come off soon for a cowl patch repair.
Glen M
macdonge is offline   Reply With Quote
Old 02-15-2018, 02:46 PM   #5
CHuDWah
CHuDWah's Avatar
Glen M
It is bolted through the sheet metal on both ends - remove the interior cowl trim panels to access the nuts.
CHuDWah is offline   Reply With Quote
Old 02-15-2018, 03:35 PM   #6
macdonge
macdonge's Avatar
Thanks CH!
Old 02-15-2018, 05:24 PM   #7
macdonge
macdonge's Avatar
CHuDWah.. Had a look just now with a flashlight. Are there 4 fasteners, i.e. 2 at the ends and 2 in the corners (bends)? It appears to be so on my car.
Old 02-15-2018, 06:58 PM   #8
john in illinois
john in illinois's Avatar
They are attatched at ends only.
John
john in illinois is online now   Reply With Quote
Old 02-15-2018, 07:09 PM   #9
Nelson C
I've found that putting something like penetrating oil on the threads and letting it soak for quite a while can be helpful. Also, sometimes some concentrated heat from a blow torch can loosen those nuts. You don't want to force them.
Nelson C is offline   Reply With Quote
Old 02-15-2018, 10:16 PM   #10
1930marie
1930marie's Avatar
That's spot on advise - I put a couple of rags below and sprayed the threads and nuts down with PB blaster. I'll soak them for a week. Removing and installing my wife helps me, a paint job is expensive.
Old 02-15-2018, 10:43 PM   #11
redmodelt
redmodelt's Avatar
There are a couple of clips on the top side that locate the band and keep in place, should be just held in place with screws.
Old 02-16-2018, 01:44 PM   #12
CHuDWah
CHuDWah's Avatar
Correct me if I'm mistaken, but isn't that just on Fordors - i.e., non-Ford Briggs and/or Murray bodies?
Old 02-16-2018, 08:31 PM   #13
Pmsqrd
Pmsqrd's Avatar
Early 30 cowl bands, which go all the way down to the splash shield, attach differently. Also the lower molding on the cowl stops short of the firewall to allow the cowl band to go down further.
Pmsqrd is offline   Reply With Quote
Old 02-17-2018, 01:21 PM   #14
macdonge
macdonge's Avatar
Thanks for this tip Pmsqrd. Looks like mine is later '30 since band stops about 1-1/2 inches above the splash shield and the moulding extends to the firewall.
Old 02-18-2018, 01:27 AM   #15
50B
My late 1930 Sport Coupe has them and they are located where the cowl band makes the turn to go down the side of the body. I hope this helps.
50B
50B is offline   Reply With Quote
Old 02-18-2018, 04:50 PM   #16
Smurkey
Smurkey's Avatar
Be glad it's not a '29 Town Sedan. Pulling that off (and putting it on) are exercises in nervousness.
Smurkey is offline   Reply With Quote
