Old 04-03-2015, 07:31 AM   #1
Hot Rod Reverend
Hot Rod Reverend's Avatar
Default Should I pull the trigger?
http://www.ebay.com/itm/1961-1972-F...ar:1956|Make:Ford&hash=item4d2c580ad1&vxp=mtr
It seems like a good deal, but I was wondering if anyone on the site is using this current setup in their car. I have a 55 Ford Fairlane - was this a pretty straightforward install? How is the unit holding up for you?
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 04-03-2015, 03:19 PM   #2
frank long island
frank long island's Avatar
Default Re: Should I pull the trigger?
Originally Posted by hot rod reverend View Post
http://www.ebay.com/itm/1961-1972-f...ar:1956|make:ford&hash=item4d2c580ad1&vxp=mtr
it seems like a good deal, but i was wondering if anyone on the site is using this current setup in their car. I have a 55 ford fairlane - was this a pretty straightforward install? How is the unit holding up for you?
when i built my wagon i used a universal booster and master 1 inch bore {corvette style} stopped great but i had to make the mount out of box tube and flat plate also had 4 wheel disks boy i miss that car
frank long island is offline   Reply With Quote
Old 04-04-2015, 08:52 AM   #3
Ole Don
Ole Don's Avatar
Reverend, if you are running a very mild or stock cam, it will work great. My Isky cam only makes 11 inches of vacuum, so the booster wont work for me.
Ole Don is offline   Reply With Quote
Old 04-04-2015, 10:14 AM   #4
Jimz Bird
Jimz Bird's Avatar
Years ago I had a '69 Mach I Mustang with power front disc brakes. It had a black "V8" can (at least it looked like that) as a vacuum reservoir.
Is that something that can be added to older cars to augment low vacuum for power brakes from a cammed engine?
Jimz Bird is offline   Reply With Quote
Old 04-04-2015, 02:08 PM   #5
miker98038
miker98038's Avatar
Ted E suggested the diesel versions in another post. One of many
http://www.fordiesels.com/1999-2007-...FUuTfgodYUwAqw
miker98038 is offline   Reply With Quote
Old 04-04-2015, 08:52 PM   #6
RalphG
RalphG's Avatar
Another option might be the "hydro boost" like the stock pump on my 81 GMC with the 5.7 diesel. The p.s. pump supplied hydraulic boost for the power brakes. It has worked great on my old pickup for the last 34 years even after I switched to the gas V8 engine.
RalphG is offline   Reply With Quote
