10-12-2016, 10:41 AM | #21 | |
Re: Vinegar flush
10-12-2016, 11:08 AM | #22 |
Re: Vinegar flush
And when you were there and done that please tell us what happened! Wayne
10-12-2016, 11:45 AM | #23 | |
Re: Vinegar flush
If I can't get a lye solution to hot tank the block, then I'd make a block off for the water inlet on the side of the block and fill the engine with Evaporust. |
10-12-2016, 04:02 PM | #24 |
Re: Vinegar flush
We don't have evaporust here - well, I've never come across it.
10-12-2016, 04:05 PM | #25 | |
Re: Vinegar flush
http://www.evapo-rust.com.au |
10-12-2016, 04:06 PM | #26 | |
Re: Vinegar flush
I don't use a rebuilder so asking him to hot tank it isn't possible. The machine shop I use to do work I can't do myself doesn't have a hot tank - they are machinists.
10-12-2016, 04:17 PM | #27 |
Re: Vinegar flush
Evapo rust is available from Supercheap stores here, but outside the US is stupidly expensive.
Metal Rescue seems to be only a few dollars more expensive than the US price, available here from Autobarn stores. |
10-12-2016, 04:50 PM | #28 |
Re: Vinegar flush
Thanks, Updraught.
10-12-2016, 05:01 PM | #29 |
Re: Vinegar flush
10-12-2016, 05:11 PM | #30 |
Re: Vinegar flush
Molasses solutions tend to get heavy with residue crud and such. The longer parts are immersed into such a solution, the worse the muck seems to become over time. Me, I'd worry over that debris getting stuck if inside a radiator for a length of time. From my own experience in using molasses to remove rust, I have always had a sludge build up from the junk and rust it removes. Okay to do parts with for rust removal, but I'd reconsider for use in a radiator, myself.
10-12-2016, 06:34 PM | #31 |
Re: Vinegar flush
Sorry Mitch, I didn't mean to ignore you.
How do these prices compare to what you pay over there. It seems pricey to me. 1 Litre $100.62 Add to basket (makes 6 litres) 5 Litre $407.90 Add to basket (makes 30 litres) 20 Litre $1623.16 Add to basket (makes 120 litres) One US gallon is close to 3.8 litres. 5 litres is about 1 1/3 US gallons. That makes it $308.37 a gallon. Maybe Updraught was right about it being stupidly expensive.
10-12-2016, 06:37 PM | #32 |
Re: Vinegar flush
at 308. a gallon, wouldnt it make sense to buy a new radiator first?
10-12-2016, 06:47 PM | #33 | |
Re: Vinegar flush
This highlights the different price dynamics between here and there.
10-12-2016, 06:59 PM | #34 | |
Re: Vinegar flush
Hey! I've got a question! In the AU (Australia?) link, it says "good for firearms" As far as I knew, the Aust. Govt grabbed all the guns. Unless.......Many found their way into ponds, wells, and streams? Inquiring minds would like to know!
Terry Quote:
10-12-2016, 07:16 PM | #35 |
Re: Vinegar flush
Not sure on those calculations ... but I think it is something like 2x the US price. I was looking at filling a petrol tank.
Maybe to fill a block its not too bad. There is an Aussie version RustedSolutions but you'd have to pay freight. |
10-12-2016, 08:14 PM | #36 |
Re: Vinegar flush
We clean them up and send them to the US. We get a good price from all those Al Capone types. We then spend our days on the French Riviera.
10-12-2016, 08:28 PM | #37 | |
Re: Vinegar flush
:d
All steel from pedal to wheel |
10-14-2016, 10:58 AM | #38 |
Re: Vinegar flush
Home Depot has evapo rust for $22 a gal.
1931 Model A Coupe Wisdom is not a product of schooling, but of a lifelong attempt to acquire it. |
10-14-2016, 11:34 AM | #39 |
Re: Vinegar flush
looks like someone might be taking a ride into Sydney this weekend!
nice save Shortdog. |
10-14-2016, 12:08 PM | #40 |
Re: Vinegar flush
In case one does not know it, vinegar can be bought in different strengths or the adidity strength can be increased by mixing it with a lower strength vinegar added into a higher strength vinegar. Regular white distilled vinegar is usually 5% acid, Heinz Cleaning vinegar is 6% acid, apple cider vinegar is maybe 8% acid and pickling vinegar is 10% acid. There are methods as mentioned to increase the acidity both on YouTube and on the net.
I have seen posts on Ahooga over the years in which the person claims that using apple cider vinegar on a carb restoration allowed them to sit the part up on a shelf for years with no residual rust. I can't swear that such works like that as I have not tried it myself. |
