Old 02-01-2017, 10:37 PM   #1
a400fordcars
Default 1932 4 cyl muffler and down plpe
Looking for a muffler and down plpe for a 1932 4 cyl does anyone know who sells these. I have the tail plpe but that's all
Thanks Brian
a400fordcars is offline   Reply With Quote
Old 02-02-2017, 12:04 AM   #2
VeryTangled
VeryTangled's Avatar
Default Re: 1932 4 cyl muffler and down plpe
Hi Brian. My help, because I don't know where to find these parts, would be: Let us know if you're going for a restoration/point car, or not.
-Jeff H
Old 02-02-2017, 02:34 AM   #3
rbullockv8
rbullockv8's Avatar
I hear you. I bought two of these years ago for my 32 Model B. Both are different angles. Neither is right; one isn't even close. Can't remember where I got them. I'm making one work by using some flexible exhaust pipe as a connector to the muffler--maybe temporarily until I can drive it to a muffler shop. I also have the tail pipe parts, and they are correct. Not sure why this is so hard.
1932 Model B Roadster Pickup
rbullockv8 is offline   Reply With Quote
Old 02-02-2017, 07:18 PM   #4
jim1932
jim1932's Avatar
Last I knew the down pipe was available, but the muffler is not. I found a tractor muffler for mine that is similar to what is on there. I have been told the v-8 mufflers work.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 02-04-2017, 07:13 AM   #5
32Bee
If you're interested, I can send a copy of the original factory blueprint to you
giving exact details concerning the inlet pipe coming off of the manifold. Originally the Model B inlet pipe and domed end muffler were welded together
as a unit and referred to as the "muffler assembly". You then can find a local
muffler shop in your area that should have the ability to bend a correctly shaped
inlet pipe for you. For years I ran a Burton Waldron inlet pipe and V-8 muffler on
my 32 5win and am in the middle of building a correct original exhaust for my B.
Peter
32Bee is offline   Reply With Quote
Old 02-04-2017, 11:42 AM   #6
Steve Seidl
Steve Seidl's Avatar
I have a nod Kent muffler for 32-34 Fords.Let me know if interested, can send pictures.nr
Steve Seidl is offline   Reply With Quote
Old 02-04-2017, 11:44 AM   #7
Steve Seidl
Thanks Brian
I have a 32_34 nos muffler still in box.:byū<>
Old 02-04-2017, 02:03 PM   #8
1931 flamingo
1931 flamingo's Avatar
My thoughts are their aren't that many "original" 32-34's around still running the 4 cyl, unlike the Model A's. It might be possible to "modify" an A muffler's pipe to mate with the B motor??
Paul in CT
Old 02-04-2017, 02:17 PM   #9
a400fordcars
Yes if you could send pictures that would be great, also price? Thanks
Old 02-04-2017, 02:41 PM   #10
DavidG
DavidG's Avatar
1931 flamingo,
More than you might think.
You might be able to modify a Model A pipe to fit a '33-'34 four, which share what is basically the same exhaust manifold, but the differences between the A and B exhaust manifolds and muffler inlet pipes are significantly greater.
The photo below depicts a weathered NOS '32-only four-cylinder muffler and inlet pipe assembly for 106" wheelbase chassis.
Old 02-04-2017, 02:50 PM   #11
hardtimes
hardtimes's Avatar
Thanks Brian
Hey Brian,
Maybe helpful to know that a 'muffler shop' has a pipe expander device that probably can / will make you the proper sized connecter piece to fill your need.
Also, some model a suppliers sell a short piece that has inside sized pipe on one end and expanded size outside pipe on other end. Hope this helps you !
Would you show pictures of your car/engine for us who like such
Old 02-04-2017, 05:29 PM   #12
Charlie Stephens
Brian,
Add your general location to your profile and someone might have an original (or one of the excellent reproductions by Mike McKennett several years ago but no longer available). You could take an original or a good reproduction to a muffler shop and have the parts you need fabricated.
Charlie Stephens
