10-09-2014, 02:46 PM | #1 |
EVANGELINE Henry's Boat and Mistress
Powered by what else, a FORD. Some nice old photo's of this boat and the Rouge plant. Henry is behind the wheel in this photo with one leg partially covering the boat's name. Interesting story too. Part one as posted on Woodyboater. http://www.woodyboater.com/classic-boats/ford/
10-09-2014, 02:49 PM | #2 |
Re: EVANGELINE Henry's Boat and Mistress
Neat photo. We sure dress differently for boating today. Thanks for sharig.
10-09-2014, 02:52 PM | #3 |
I believe you are wrong about him being behind the wheel (not that it matters) since boats are most always right hand drive, even to today. What's up with that anyway?
10-09-2014, 02:58 PM | #4 |
Photo and description are from the The Rosenfeld Collection. Boats of this era had the wheel on the left. There are more famous people in the photo if you care to read the story.
10-09-2014, 03:06 PM | #5 |
10-09-2014, 03:39 PM | #6 |
10-09-2014, 03:40 PM | #7 |
Awesome pictures !
I think the 2 race boats on the left are Gar-Woods and it looks like the engines are liberties. What kind of Ford motor is in Fords boat ? I like those old wooden critters and they tend to be ambidextrous [sp]. It depended on who built it. Last edited by Patrick L.; 10-09-2014 at 03:53 PM. |
10-09-2014, 04:21 PM | #8 |
It looks to me like the person on the right side of the windshield has his hands on the wheel, which would make it right hand steering. My 1959 Crestliner has the steering wheel on the left, and I read in the sales lit that it could be ordered either way.
10-09-2014, 04:21 PM | #9 |
10-09-2014, 04:43 PM | #10 |
I'm more concerned about the poor guy who appears to be DEAD in the boat on the right!
10-09-2014, 04:46 PM | #11 |
Second photo is the same boat Evangeline as viewed from the barrel back stern. Yes, Garfield Wood is also in this photo. All your questions can be answered by reading the story and there are more photo's of Henry as well as more boat photo's and it's current condition and the motor. http://www.woodyboater.com/classic-boats/ford/
10-09-2014, 04:52 PM | #12 | |
The term "starboard" comes from Old English steor bord (steer side), so-named because before centerline rudders became the norm on sailing vessels, the steering oar was located on the right side of a vessel. By contrast, the port side of a vessel was originally called "larboard" (load side). Vessels would dock for loading on the port side, and if the steering oar had been located on that side, it would get in the way of docking. |
10-09-2014, 04:56 PM | #13 |
The second photo of the boat doesn't seem to be flipped as what I'm assuming is a step plate is on the left hand side on both pictures.
10-09-2014, 05:09 PM | #14 |
Thanks for posting this. I should have read the story, its amazing. Couldn't stop. And it makes sense what engine it would have.
10-09-2014, 05:14 PM | #15 |
Interesting photos. But the second photo doesn't match the first, there is no windshield at the rear cockpit, and no evidence of one being mounted, no holes. It may be the same Evangaline, but they were taken at different times. No matter, it is still interesting. Thanks for posting this bit of history. Vern
10-09-2014, 07:54 PM | #16 |
Beautiful boat and some cool history! The later photos of the boat show it as left hand drive also. While most boats may be right hand drive this was more or less custom built for Henry so if he wanted it LHD I'm sure they accommodated him on that. Thanks for sharing!
Aaron in Tacoma (although still a Montana hillbilly at heart ) |
10-09-2014, 09:28 PM | #17 |
Early Chris-Craft boats used Model A steering boxes and many Detroit auto executives used Garwood, Hacker and Chris-Craft boats as commuters in the late twenties and early thirties.
No restorable Model A's were harmed in the building of this truck! |
10-09-2014, 10:38 PM | #18 |
I'm used to looking at pre-war boats with left hand drive so it doesn't seem unusual to me. There are four of them in this photo I took in Hessel.
10-10-2014, 01:43 AM | #19 | |
I'll see If I can clarify this which was told to me by my uncle a boat builder up to 72 footers. This is all about the engine configuration. The easiest casting for the marine gear was driven off the front of a standard rotation engine so now the prop shaft turns clockwise right. And then, by some to cast a real rear bellhousing (more expensive) so now the prop shaft turns a normal left. This is what determines which side the helm is built. Most larger twins the helm is usually in the center. I think front driven reverse gear setups were phased out maybe mid fiftys. So I my brain tells me & I got CRS all those pics above with right helms turned standard rotation props. Last I had was a 30' 1939 Elco Flathead Chry. marine front driven gear right hand prop, helm on the port side. sam |
10-10-2014, 05:41 AM | #20 |
The article clears up this steering wheel issue nicely.
10-10-2014, 09:57 AM | #21 |
When I was in the business of building and selling "Flat Bottom V-Drive" Ski, Drag and Marathon boats, we placed the steering wheel per prop rotation. The majority of these types of boats in the day were connected to the v-drive from the flywheel engine end. The v-drive reversed the rotation making it left hand at the prop shaft. As these boats caught a great deal of air at speed, controlling the prop torque was to be considered along with the engine torque. So we placed the steering wheel on the left, the fine old boats shown in the photos above really never came out of the water like a powerful v-drive. We also offset the rudder to the left to counteract the torque steer to the right as a result of the prop. This also made it much easier to pull the shaft if needed.
Our blown fuel hydro drag boat that we set the record with was a counter rotating twin screw, prop torque was not a problem and it steered itself, all you had to do was hang on. Sorry if this is off topic a little but someone did open the door on wheel location. Thanks to the gentleman that posted the excellent photos!
Steve - Santa Rosa Last edited by callcoy; 10-10-2014 at 10:12 AM. |
10-10-2014, 12:58 PM | #22 |
10-10-2014, 03:49 PM | #23 |
09-11-2017, 07:12 AM | #24 |
Digging up an old thread.
Evangaline is for sale. https://m.youtube.com/watch?v=tGIyiDgPVL8 https://m.youtube.com/watch?v=vg62RpcYmYE There have been updates to the story since this thread. http://www.woodyboater.com/blog/2015...cker-part-2-1/ Twin updraught Zeniths and 450hp. http://www.woodyboater.com/blog/2015...bout-part-2-2/ |
09-11-2017, 07:28 AM | #25 |
It is sweet!(The boat I mean) Looks to be a mid thirties Chris Craft, but there were other makers. CC made a lot of those triple Cockpit, engine amidships, 27 foot and up, boats. They make me saiivate. The race boats, as someone said, look like Gar Woods with Liberty engines. Nice Picture!
Terry I see the boat is a Hacker, not a Chis Craft, and it is a 1924! Very advanced for 1924! It looks like a mid to late 1930s "Barrel Back". This boat is a mind blower! What else for HF? Last edited by Terry, NJ; 09-11-2017 at 07:52 AM. |
09-11-2017, 09:40 AM | #26 |
Bill Carguy
09-11-2017, 10:54 AM | #27 |
8 Ton Sledge: Gar Wood’s 6400 HP Miss America X Boat Owned The World In ’32 and ’33.
click to see article: https://bangshift.com/general-news/v...-and-33-video/ Engineers told Gar Wood that it was impossible to build a transmission box to hook the two 1600 HP Packard engines together ... So he built two of them, one for each pair of engines ... Gar Wood says in video that the HP is 6400 ... Article says 7200 and 7000 in title. I know that the later engines were super charged so that might be the difference. Legend has it that Gar Wood's boat designs were used to make the PT Boats of World War II fame. Last edited by Benson; 09-12-2017 at 08:24 AM. |
09-12-2017, 06:11 AM | #28 |
I found it interesting that the boat, while owned by Mr Ford, was called "Evangeline" according to the boat mechanic interviewed in the early 50's.
Don't try this at home folks. Naming your boat after your mistress may not be good for your health. Google "evangeline cote dahlinger" for more info on the name. |
