Old 03-25-2011, 10:25 AM   #1
Six Pack to go
Six Pack to go's Avatar
Question 1934 HELP...windshield regulator instalation?? post pics please?
Trying to figure out how the stock window regulator goes on my 1934 Ford coupe...please post pics if you got em...Thanks ~Eric
Flatheads forever!
Six Pack to go is offline   Reply With Quote
Old 03-25-2011, 11:14 AM   #2
DICK SPADARO
Default Re: 1934 HELP...windshield regulator instalation?? post pics please?
There are 11 posts answering this question on the HAMB post!
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 03-25-2011, 11:20 AM   #3
Six Pack to go
Still no pics of a stock installed one...And I bought itfrom you! So mabe I should take my business elsewhere!
Flatheads forever!
Old 03-25-2011, 11:33 AM   #4
Six Pack to go
Figured out the problem, my dash was filled! There is no whole for the handle....mabe its a roadster dash, I dont know.
Flatheads forever!
Old 03-25-2011, 11:47 AM   #5
DICK SPADARO
If you bought it from me and have an installation problem you can always call 518-861-5367 M-F 9-5 ET for an answer. The pictures addressing your other post showed you how it mounts to the cowl. If the dash board does not have a hole for the regulator to pass thru then it must be determined if it is a cabriolet dash or someone just welded the hole up because the car had a fixed windshield before you got it. Cabriolets had no hole and dashes are hared to find. Doubtful its a roadster dash they are totally different than a closed car dash. If you are still having problems call for assistance.
dickspadaro.com
Old 03-25-2011, 05:03 PM   #6
Six Pack to go
This is the dash in my coupe hence the problem I was having....mabe someone can identify what type of 33/34 it may have come from....its an old hot rod and Im no expert...that was the reason for the post. Ford Barn has the purist and I thought someone could help me...that is the reason for the double post. I couldnt figure out where the handle went. Now I know that this dash is not origional to my coupe or someone filled the hole...thanks for your assistance. ~Eric
Flatheads forever!
Old 03-25-2011, 05:50 PM   #7
David J
David J's Avatar
Talking Re: 1934 HELP...windshield regulator instalation?? post pics please?
Eric , Left two pics are 34 dlx and the other two are 33 dlx . Your dash looks to be a standard { no ashtray or cigar lighter } but it has had work done to it . I took the handle off the 33 so you can see the hole is oblong to allow for shaft movement as you crank the windshield in and out . If interested I can cut this segment out of a cannibalized dash . David J
Last edited by David J; 03-25-2011 at 05:56 PM. Reason: get words in order with pics
David J is offline   Reply With Quote
Old 03-25-2011, 09:48 PM   #8
Six Pack to go
Thanks for the pics, I think my dash was filled some time ago...I will make it work. Thanks ~Eric
Flatheads forever!
