Old 10-04-2019, 12:28 AM   #1
Recycle1947
Default Running 2 carbs on a 3x2 manifold
I have a 49 8ba bored .100 over and 3/4 cam and Offy heads to put in a '30 A coupe. I want to run 2x2 carbs on it. I can get an Offy 3x2 manifold for reasonable money. Will the motor have good performance with the center carb spot blocked off and just running the outer carbs which will sit over the intake ports like the Offy 7106? Or should I keep looking?
Recycle1947 is offline   Reply With Quote
Old 10-04-2019, 01:01 AM   #2
RalphM
RalphM's Avatar
Default Re: Running 2 carbs on a 3x2 manifold
2x2 manifolds are designed for two carbs, and are not expensive or hard to find. I’d keep looking.
RalphM is offline   Reply With Quote
Old 10-04-2019, 01:02 AM   #3
RalphM
RalphM's Avatar
Old 10-04-2019, 02:33 AM   #4
Tinker
Tinker's Avatar
Probably okay. There also voids from the block off. Not bad, but could be better.
Old 10-04-2019, 09:16 AM   #5
Ol' Ron
Ol' Ron's Avatar
Not a problem, on a street engine. But no matter which intake you use, you'll have to change the distributor. Also milling the heads for .045/.050 piston to head clearance will improve throttle response an mileage. Well worth the cost.
Old 10-04-2019, 01:22 PM   #6
JSeery
JSeery's Avatar
Fairly common to block the two outside carbs or the center carb. Wouldn't think it would make much difference at low rpms.
