06-12-2015, 12:45 PM | #1 |
'40 front brake hose to short
Does anyone have a part number for a front brake hose 19" long?
06-12-2015, 01:09 PM | #2 |
Re: '40 front brake hose to short
Does it matter what the ends are? male/female Chevy, Ford.
Really, I'm Trying |
06-12-2015, 01:24 PM | #3 |
I would think " '40 front" on an old FORD forum would make that fairly clear. The real question might be.......Why so long? 15-3/4" is normal length. DD
06-12-2015, 02:14 PM | #4 |
The # is for stock FC7600 15 9/32 long Front
You could try FC4774 18 13/32 Same thread. The mounting hole must have been changed. |
06-12-2015, 02:49 PM | #5 |
My bad, I was on the HAMB before and it was just a reflex.
06-12-2015, 03:20 PM | #6 |
Early Ford Store has them. 18.2" long
Chisel Evil Lurks...for those that don't carry a side arm!!! |
06-12-2015, 03:56 PM | #7 |
Sorry, I should have been more clear. I am putting '40 brakes on my '32. The hole in the frame is drilled just behind the stock shock, this makes a stretch for a 16 7/8" hose. No room for suspension flex, that's why I am thinking 19" will work good.
06-12-2015, 04:01 PM | #8 | |
Karl |
06-12-2015, 06:55 PM | #9 |
Wagner Raybestos 4497 is longer than the 40 front hose.
John |
06-12-2015, 07:46 PM | #10 |
I had a similar hose length problem. I found that searching NAPAs online cat will give you a hose that will work. It may take some time searching thru the many options but you find one that will work. Here is an example
http://www.napaonline.com/Catalog/Ca...242_0342278658 I'll look for the part# I used in the morning. |
06-13-2015, 06:17 AM | #11 |
The Wagner FC 4774 is 18 13 /32 try Plymouth 35-38
FC 4950 Divco and IHC 20" long. |
06-13-2015, 09:32 AM | #12 |
Another option is to have them made--the local hydraulic hose place here can make brake hoses ---any length up to what's on the roll in one piece
06-13-2015, 09:56 AM | #13 |
Go to your local Napa store. Have the counterman get out the brake hose buyers guide. In this catalog you will find descriptions of all the hoses that Napa lists, by length, type of fittings and any mounting brackets.
06-13-2015, 08:35 PM | #14 |
Thanks for the help. Going to NAPA to go through their book.
