08-13-2023, 08:59 PM | #1 |
Cylinder Head Plug
Never thought this would be so hard.
Have an aluminum cylinder head with a 5/8" NPT female joint beside the radiator hose outlet. On the passenger side it's filled by a temperature sender. On the passenger side, well, it's unused. Need a 5/8" NPT aluminum pipe plug to plug it. Can't find one anywhere. Spent hours on the internet. Anyone know where to get one of these? I have a blue anodized aluminum 5/8" NPT 90 degree elbow to heater hose fitting left over from a SBC project that I'll make work somehow with a cap but obviously, that will stick out like a sore thumb. |
08-13-2023, 09:13 PM | #2 |
Re: Cylinder Head Plug
08-13-2023, 11:17 PM | #3 |
Sure it's 5/8 NPT? Reason I ask is that 3/8 NPT measures very close to 5/8" and is a common size, and is used for most flathead Ford temp senders.
Terry
08-14-2023, 05:54 AM | #4 |
Here you go
08-14-2023, 09:32 AM | #5 |
I'm quite sure it will be 3/8 NPT. Never heard of 5/8 NPT and I am a plumber.
08-14-2023, 09:45 AM | #6 |
It's the same size threads that are on 8RT (and other)water pumps. Don't overtighten it. You could also use a brass pipe plug instead of aluminum. Last edited by 19Fordy; 08-14-2023 at 10:13 AM. |
08-14-2023, 09:57 AM | #7 |
You need a 3/8" NPT and don't for a minute use aluminum - you'll never get it back out.
I'd use a stainless plug if it was mine - with an allen head type receptacle. Also, use a Teflon type sealer - to lubricate and seal the threads. |
08-14-2023, 10:17 AM | #8 |
I never heard of 5/8 NPT either
08-14-2023, 10:37 AM | #9 |
08-14-2023, 12:06 PM | #10 | ||
A 5/8"-18 tap runs down the hole with no cutting or resistance.
Got out my KS temperature sender and fit's securely in the hole. Would have sworn it has 5/8"-18 NPT threads. The picture measuring the distance across the threads is the key for me. Must be 3/8" NPT. 3/8" NPT thread count is 18 TPI which explains why the 5/8"-18 tap ran down the hole. Mystery solved. Quote:
I believe you. Probably DOESN'T exist. WARNING: don't ask me for help measuring threads. |
08-14-2023, 12:24 PM | #11 |
3/8 NPT is 18 TPI with .675 OD
08-14-2023, 01:45 PM | #12 |
I have authentic brass plugs for this.
08-14-2023, 08:23 PM | #13 |
Also, given that this is a NPT type thread - it is tapered, not straight like a regular 5/8 18 tap creates.
08-14-2023, 10:09 PM | #14 |
I like the brass plugs with a hex head for a wrench, not the square thing. And yeah, never heard of 5/8 pipe thread.
08-16-2023, 07:18 AM | #15 |
SoCalCoupe>>>A 5/8"-18 tap runs down the hole with no cutting or resistance.>>>
This means that you can also use a 5/8-18 bolt or screw with a ring seal. Aluminum bolts & screws are available. The Brits mix & match tapered & parallel pipe threads this way. |
08-16-2023, 09:04 AM | #16 | |
Glenn |
08-16-2023, 10:39 AM | #17 |
It's interesting to see the confusion "Normal" people" react to mechanical things????
Gramps |
08-16-2023, 10:52 AM | #18 |
Sorry, no. Aluminum nspt isn't common. And aluminum is preferred in this case to help avoid electrolysis. He also said a 5/18-18 tap ran down the hole. So taper isn't causing an interference problem if the tap ran past its own taper. He just needs a ring seal and an 5/8" fine thread aluminum bolt or plug. Automotive aluminum plugs are in fact made for this purpose.
08-16-2023, 12:00 PM | #19 |
Sorry, don’t use aluminum as has been mentioned here. Brass with anti- seize.
The original poster needs to tell us if he really re-tapped the hole because a 5/8 will go in a few threads and then the taper will stop it IF checking by hand and not using a tap wrench |
08-16-2023, 01:34 PM | #20 |
Rather than find a plug for that hole, why not use it as intended, have a sender in each head. You will need to use this sender(actually just a switch) as the first sender:
https://thirdgenauto.com/product/new...original-type/ Last edited by JayChicago; 08-16-2023 at 01:42 PM. |
