Old 08-11-2023, 06:38 PM   #21
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Advance lack of response on RPM on a 31
Have y'all tried removing the Pertorix and using points?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 08-11-2023, 06:42 PM   #22
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Phil Brown View Post
Try a distributor with an old set of points in it if you can, if it runs better or ok then that probably confirms what Bob said
Originally Posted by nkaminar View Post
I have not had very good luck with electronic ignition. A lot of people swear by them but not me. I went back to the mechanical points and condensor. Although I do use V8 points and condensor.
Originally Posted by Flathead View Post
Testing it with the points and condenser should help to solve this.
Originally Posted by Ruth View Post
I would install stock type points and condenser and test it.
Has anyone suggest trying points yet?
Old 08-11-2023, 09:05 PM   #23
Banditorama
Originally Posted by old31 View Post
NK, what are the differences with the v8 points vs the standard?
I am a huge proponent of electronic vs points. No condenser to go bad, nothing to adjust.
Think about it, American auto makes have been using electronic since the 80's. When was the last time your new or antique car died due to the electronics.
I've experienced more sensor/module issues in my "newer" cars than any mechanical faults. My old 93 Mustangs PCM failed due to electrolytic capacitor failure
I don't even know where to start with my TDI VW. That thing has been a nightmare. Those Germans seem to love burying the most failure prone sensors as deep under everything as they can.
Banditorama is offline   Reply With Quote
Old 08-12-2023, 12:49 AM   #24
Pete
Pete's Avatar
Do you know exactly how much advance you have when adjusting various things?
Different engines require different advance curves and amounts depending what modifications have been done or not done.
If you haven't already, get some timing tape and get ready to install it on your front pulley, then get a timing light. Next, determine where top dead center on #1 cylinder is by using the timing pin in the cam gear cover. DO NOT TURN THE ENGINE FROM HERE ON.
Now make a pointer to install under one of the front cover bolts. Put it so you will be able to see it easily with the timing light shining on it. Now install the tape with the ZERO exactly under the pointer. This is top center and you will be reading degrees advance or retard at this point in relation to the tape on the pulley. You will probably have to re-calibrate the pointer if you ever remove it.
Now fire up the engine and observe where the timing is set and if it advances and how much, with rpm.
All of this won't cure the problem you are having but it will enable you to know what is actually going on when you change something.
