07-18-2023, 10:15 AM | #1 |
Marvel float adjustment
I have my float measured with the gasket on and from the gasket to the float bowl seam is 15/16 of an inch.
I also have a quarter inch from the top of the float bowl with the carburetor "upside down" a quarter inch to the gasket. Is that good enough or do I need to measure the float level with a tube? If the answer is yes what should the float tube level be, and how is it measured. Last edited by old31; 07-18-2023 at 09:28 PM. |
07-18-2023, 08:19 PM | #2 |
Re: Marvel float adjustment
I usually, with the top of the float bowl inverted, just set the top of the float parallel with the gasket surface of the float bowl top. YMMV
07-18-2023, 11:31 PM | #3 |
