03-30-2023, 12:51 PM | #1 |
Marvel carb Idle Adjusting Needle
With a Marvel, when you turn the Idle Adjusting Needle in, (clockwise) are you increasing or decreasing the amount of fuel being used.
My plugs look a little dark, and I am not sure which way to go.be Last edited by old31; 03-30-2023 at 01:11 PM. |
03-30-2023, 12:58 PM | #2 |
Re: Marvel carb Idle Adjusting Needle
See table
03-30-2023, 01:13 PM | #3 |
So, based on the table, if I’m running a little rich, I would want to move the needle out is that correct?
03-30-2023, 01:49 PM | #4 |
No, sorry, the table is a little ambiguous. The headings correspond to the condition you want, not the condition you're trying to correct. Turning the Marvel idle screw out will richen the mixture. The way the Marvel carbs are constructed, the idle screw needle controls the entire fuel-air mixture coming from the idle circuit, which mixes with air coming through the throttle body to form the total FAM. So if you turn the needle in, you're decreasing the amount of fuel in the mix.
03-30-2023, 01:53 PM | #5 | |
Thanks! I was questioning myself... |
03-30-2023, 02:42 PM | #6 |
To recap; turn the mixture screw IN/clockwise to LEAN the idle mixture, and OUT/counter-clockwise to enrichen it. |
03-30-2023, 03:12 PM | #7 | |
IMO that table should be trashed. It can easily be construed to do exactly opposite what should be done (as old31 assumed in post #3). The idle adjustment screw controls the fuel flow on a Marvel, so to increase the flow (enrichen) you turn it out (counter-clockwise). On the Tilly and Zenith, the idle mixture screw controls the air flow. Last edited by Y-Blockhead; 03-30-2023 at 03:19 PM. |
03-30-2023, 04:35 PM | #8 | |
The Zenith design puts the idle mixture adjustment needle in the path of the air bleed. Close it off and the FAM gets richer. The Marvel design puts it just before the air bleed, after the bypass air has mixed with fuel. Close it off and the FAM gets leaner. |
03-30-2023, 06:31 PM | #9 | |
Instructions for adjusting a Marvel/Allstate/Johnston |
