05-01-2021, 12:31 AM | #1 |
L-100 & 9" clutch
Thanks to 'Scott' my '32 pickup is back on the road. We pulled the motor...before the covid crisis in the family (everyone back home now)...to
have Moriarty install the L-100 cam from KIWI Tony Price and switch the clutch to a new Van Pelt 9". The cam is so much more than I could have wished for.........the idle every flathead guy dreams of, very decent low end and pulls hard all the way up. I could go on and on, I'm a happy man. Lincoln springs from 3rd Gen and European adjustables from Van Pelt ( looked and felt like Johnsons ) 9" clutch from Van Pelt so smooth but a solid pedal & 3/5's the weight of the 10" . Charlie ny |
05-01-2021, 03:03 AM | #2 |
Re: L-100 & 9" clutch
Good info. What CI is your engine?
05-01-2021, 04:51 AM | #3 |
Thrilled that your such a happy man Charlie. With all the great work you do for so many putting a smile on their faces it is great the we could return the gesture. Cheers.
05-01-2021, 06:18 AM | #4 |
ref #2.....'49 Merc 286 cu in, EAB heads min clearance.
Charlie |
05-01-2021, 08:33 AM | #5 |
Back in 87, I was working in a body shop fixing rusty Vermont cars, when a fellow came in as asked if anyone could build a flathead. I raised my hand, and thus started a new life.
That Saturday I went to his shop and looked at his parts. Kong heads with the spark plugs so far up the heads, I was suppressed to see they were still in the combustion chamber. And a cam made for Bonneville Intake was 245 at .03" lift. Then he showed me what it was going in. A 1942 Ford ambulance. (5500lbs) I tried to explain to him that the cam wouldn't work and the head had 4 to 1 CR at most. He said , "It\s all paid for, so that what we use." The 276?? went together with only a few problems. Couldn't use the copper head gaskets as they leaked like a sive. Had to us some plastic ones he had. The original intake and dist ributor wer bolted up and off we went to York PA. Engine sounded like a Hemi and wegot 18 MPG cruised along at 70 plus, and I fell in love with the L-100 I knew David Generous personaly. He had a shop in Milford Ct and I was living in Stratford CT. He was building engines for the Datsum race team with another fellow and grinding cams. This was his flathead cam. After I opened up Nostalgia engines, it was my standard cam, unless the customer wanted something else. I sen David dozens of stock cams so he had allot of cores I often wondered if the L-100 would had ever got off the ground, if it wasn't for GEORGE asking me to build him an engine. I still don't have any Idea why it works so good. Gramps |
05-01-2021, 07:14 PM | #6 |
05-01-2021, 07:21 PM | #7 |
The brothers also had the “patented” for the “dial bore gauge as we know it today. Very Sharp men.
05-01-2021, 07:49 PM | #8 |
Yes, David told me the whole story. I have a list of all the cams they designed for the Ford engines. One cam L-94 , I used in the 258 Hydro engine amd that went into the history books.
05-19-2021, 06:33 PM | #9 |
New here
Wondering where the L 100 is available to purchase? |
05-19-2021, 06:49 PM | #10 |
Tried to send a PM to KiWinUS but I have not yet met the required post count
So. The PM below Hello, New guy guy here. Wondering about the L 100 cam that I am reading so much about here I suppose that I should tell you about what I have, to see if the 100 will be appreciate foe me I have a 40 Tudor with the original(tired ) engine. I see a rebuild perhaps this winter The engine is all stock so I guess a pretty clean slate I'dlike for it to be a dependable DD , modified slightly like a guy in the 50-60s would doo it Dual 94s, dual exhaust Your suggestions appreciated |
05-19-2021, 07:01 PM | #11 |
"outside347" - Make sure that you look into the information posted here on optimizing quench in the heads. It is done by milling the heads to the minimum clearance and then custom fitting them to the piston tops. In my opinion, it is the single most effective thing that can be done to a flathead to increase efficient combustion. Efficiency adds BOTH economy and power.
Other than that, increasing displacement is a good way of increasing power. It is expensive, and a little more difficult with the early 221 ci engines. At the very least, you can respond to this post and up your post count which will get you closer to the 10 posts you need to be a "real" member. |
05-19-2021, 07:10 PM | #12 |
Tks tubman. Makes sense Much to learn
Would you suggestion require new pistons? |
05-19-2021, 08:00 PM | #13 |
The configuration of the tops of your existing pistons is probably fine. The problem with reusing the originals is more a matter of wear and age.
In my experience, count on replacing them. |
05-20-2021, 11:12 AM | #14 |
05-20-2021, 04:28 PM | #15 | |
E Mail sent |
11-28-2021, 11:26 AM | #16 |
I can’t pm you as I don’t have 10 posts yet. Im interested in the L-100 cam. Do you still grind them. If yes, would I need to send my stock cam to you?
Thank you. Dean Ellis |
05-21-2021, 04:51 PM | #17 |
whew! Love this post!
11-28-2021, 11:29 AM | #18 |
G’day Dean.Yes still grinding the KiWi-L100. Email me @
[email protected] I can help you out. Cheers Tony |
11-28-2021, 11:37 AM | #19 |
Charlie, did you use the stock 9" pressure plate, or heavier springs to make it hold ?
11-28-2021, 02:03 PM | #20 |
I don't thik the L-100 would work very well in a stock displacement engine in a heavy car. Torque i
s what moves the car and the long duration of the cam reduces the lowend torque. By boring and stroking the engine you increas the lowend torwue and the head work increases the CR as well. Planing an engine build you must consider the application. remember, a "Street engine " spends 90% of it's time in cruise!!! Gramps |
