11-05-2021, 04:45 PM | #1 |
8BA road draft tube OD
Or the ID of the hole in the manifold for the road draft tube ?
Looks like 1 5/8" or so? Thanks. |
11-05-2021, 06:24 PM | #2 | |
Re: 8BA road draft tube OD
Not sure the exact dimension, but if you're possibly looking for a way to block it off for a PCV Valve mod, a Dorman #555-023 freeze plug is a perfect fit. Link to the thread if you're interested. DD https://www.fordbarn.com/forum/showt...pman+pcv+valve . |
11-05-2021, 07:45 PM | #3 |
I believe he is asking about the size of the exterior tube on an 8BA type manifold.
Are they the same? |
11-05-2021, 07:50 PM | #4 | |
Tub is correct.....and I blew it once again! DD |
11-06-2021, 05:54 AM | #5 |
It is 1 1/4" where it enters intake.
11-06-2021, 10:58 AM | #6 |
11-06-2021, 12:00 PM | #7 |
Do you need the tube?
'52 F-1, EAB flathead |
11-06-2021, 01:12 PM | #8 |
Naw. When the engine gets back from H&H I'm going to install a ME Wagner PCV valve on it........ I refuse to buy an aluminum plug for $40 (Jamco) when I can machine a remnant piece of 6061 in 5 minutes.
11-07-2021, 01:27 PM | #9 | |
Karl |
