Old 05-17-2017, 03:53 PM   #1
1931flathead
Default carb kit
What parts store has the best carb kit for my 1953 flathead v8
1931flathead is offline   Reply With Quote
Old 05-17-2017, 04:53 PM   #2
Tony, NY
Default Re: carb kit
NAPA is probably the only one that might have it in stock. If you can wait, why not just order one from Van Pelts or Rock Auto? I ordered one for my '59 off topic car from Rock Auto. Ordered Sunday due on Friday.
Tony, NY is offline   Reply With Quote
Old 05-17-2017, 07:41 PM   #3
Angledrive
Angledrive's Avatar
Daytona Parts, Florida 386.427.7108
Angledrive is offline   Reply With Quote
Old 05-17-2017, 08:03 PM   #4
KDL
KDL's Avatar
Second for Daytona Parts
KDL is offline   Reply With Quote
Old 05-18-2017, 06:44 AM   #5
motordr
Does the Daytona kit come with a leather accelerator pump? Thinking 94 but also 97.
motordr is offline   Reply With Quote
Old 05-19-2017, 07:46 PM   #6
1931flathead
I got one coming from Napa I hope it helps out
Old 05-20-2017, 04:59 AM   #7
big job
big job's Avatar
We buy from Napa also, but I caution all to bring the acc. pump with you because
one pump is small and the other is big. Just did a EAB marked on the fuel bowl.
Opened the box and I got the small diameter pump. Had to put the old one back in.
Then I saw utube vid of a rebuilder showing 4 or 5 kits being all different ...just sayin
sam
big job is offline   Reply With Quote
Old 05-20-2017, 07:12 AM   #8
FortyNiner
FortyNiner's Avatar
I am a recent convert to Mike's Carbs: http://www.carburetor-parts.com
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 05-20-2017, 07:46 AM   #9
TStiles
x2 Mike's Carbs
TStiles is offline   Reply With Quote
Old 05-20-2017, 12:22 PM   #10
RalphM
RalphM's Avatar
Check with some of the carb builders here on the barn.
CharlieNY does a lot of the 94 style carbs.
RalphM is offline   Reply With Quote
Old 05-20-2017, 12:36 PM   #11
Bolts
Bolts's Avatar
Mikes Carburetors
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
