Old 03-13-2017, 12:31 AM   #1
Art Newland
Art Newland's Avatar
Default brought my 49 F-1 Home
Spent some time trying to work out some of the bugs. It acted like the accelerator pump wasn't working right, after a little inspection found the linkage was missing. I fabricated a linkage from wire and it is better, was wondering how comparable the different carbs are? My carb is marked 8RT, there are several used carbs for sale over at the swap meet section, mostly marked 8BA. I'd really like to fix the existing carb, guess I'm looking for a donor carb.
Art Newland is offline   Reply With Quote
Old 03-13-2017, 01:51 AM   #2
FortyNiner
FortyNiner's Avatar
Default Re: brought my 49 F-1 Home
You'll need to be careful as the carbs for trucks (8RT) differ from the car versions (8BA). Check the mounting, orientation, and air horn. The air cleaner mounting typically was diffferent. Generally, it is possible to swap one for the other - with other small accommodatingl changes. Donor pieces are generally fine - again, watch for small differences externally.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 03-13-2017, 02:04 AM   #3
flatheadmurre
flatheadmurre's Avatar
Mechanical parts(levers etc) are the same as long as you stay within 8BA/RT family.
Top part is straight where you attach aircleaner on cars and cone shape on trucks.
Some of the vendors will probably sell you the part you need for less then a donorcarb.
Take it apart examine it get the parts you need with a rebuild kit and put it back togetter.
Old 03-13-2017, 09:42 AM   #4
Art Newland
OK, thanks, I see now that around the throat of the carb is different where the air cleaner attaches. I do have the stock oil-bath air-cleaner so I don't want to screw that up.
Old 03-13-2017, 09:44 AM   #5
Art Newland
Where do you F series guy like to by your parts? I have a couple of favorites for Model A parts and MAC's isn't one of them...
Old 03-13-2017, 10:35 AM   #6
TStiles
Hard to go wrong with C&G and Dennis Carpenter for many of the odds and ends. NOS parts are becoming harder to find as time goes on.
TStiles is offline   Reply With Quote
Old 03-13-2017, 10:39 AM   #7
DD931
DD931's Avatar
Agree. C&G first, if they don't have it then Carpenter. C&G has fantastic service!! I live in PA and when I order something from them it's always in my hands in two days.
DD931 is offline   Reply With Quote
Old 03-13-2017, 11:35 AM   #8
1948F-1Pickup
1948F-1Pickup's Avatar
I've found plenty still out there and pretty good stuff on eBay.
I just recently got a RT Holley 94 top fairly reasonably so I could
machine off the air cleaner flange for a G&C assembly, rather
than modding my original part.
My accelerator pump also needed work when I got the truck. Person
I got it from was telling me "it just needs to warm up." Turned out
that the spreaders and nozzles were clogged with crap and weren't
even close to sealed to the carb body correctly anyway.
1948F-1Pickup is offline   Reply With Quote
Old 03-13-2017, 05:10 PM   #9
Ken Crans
Ken Crans's Avatar
I use Sacramento Vintage Ford,and Midwest Early Ford both great F-1 sources.
Ken Crans is offline   Reply With Quote
Old 03-13-2017, 08:42 PM   #10
JSeery
JSeery's Avatar
I use LMC a lot for some items.
Old 03-14-2017, 12:46 PM   #11
37coop
37coop's Avatar
C&G every time for me,to here in the U.K the shipping is expensive so it needs to be right first time ,they answer all questions quickly and the website tells you if its in stock,carpenter a good second choice .
37coop is offline   Reply With Quote
Old 03-15-2017, 10:04 AM   #12
Art Newland
While I was spending a few hours of quality time trying to get the brakes lines off of the master cylinder, I was looking at the diff, I'm not real familiar with Ford's but it looks like a 9 in back there?
Old 03-15-2017, 10:34 AM   #13
JSeery
JSeery's Avatar
Check the tag that's on the center section, it should tell you.
Old 03-15-2017, 10:52 AM   #14
Art Newland
The tag says 3.70
Old 03-15-2017, 11:23 AM   #15
JSeery
JSeery's Avatar
Well, that's the ratio. There aren't any other marking on it?
Old 03-15-2017, 06:30 PM   #16
FortyNiner
FortyNiner's Avatar
This might help: http://www.ford-trucks.com/articles/...rential-swaps/
Old 03-15-2017, 08:54 PM   #17
scicala
scicala's Avatar
If all you need is the link that fell off, send CharlieNY a PM on Ford Barn. He should have parts like that.
Sal
Old 03-16-2017, 12:10 PM   #18
Art Newland
Got hooked up with a fellow flathead guy and he gave me the link.
It does work better now but everything is pretty loose/worn. The rearend seems to be an early model 9 inch, probably from a late 50 early 60 pickup, 3.70 ration doesn't sound too bad, with a 9 inch rear there are lots of ratios available. Should handle the 239's horsepower without too much problem.
