07-09-2011, 05:17 PM | #1 |
Adjust toe in
What is a good way to adjust the toe in on a 35/36 car, thanks
07-09-2011, 06:18 PM | #2 |
Re: Adjust toe in
I used a "stick" and a tape measure to mark it with a felt tip pen. Did the centerline (front and back) of each tire. Adjusted the tie-rod ends to get 1/16 inch. To check my method, I put the car on a 4-wheel alignment machine......was exactly on specs.
Remember that you need to have all rod ends and king pins in good condition, and wheel bearings adjusted properly. |
07-09-2011, 08:09 PM | #3 |
Re: Adjust toe in
Support your front axle on two equal jackstands.
Spin each wheel while holding a piece of blackboard chalk to the center of the tread to make a heavy line. Follow this with a black pencil to make an accurate fine line on the chalk. Measure the distance from one wheel (fine line) to the other at the front, and also at the rear. The front dimension should be 1/8" (2 x 1/16") shorter than the rear. Spin both wheels 1/4 turn and repeat the above to verify the setting.
Alan |
07-09-2011, 08:30 PM | #4 | |
Re: Adjust toe in
07-09-2011, 08:52 PM | #5 |
Re: Adjust toe in
If taken to an alignment shop, I think they do it on plates that can rotate. Shouldn't be a factor either way.
Alan |
07-09-2011, 08:57 PM | #6 |
Re: Adjust toe in
Bruce |
07-09-2011, 09:07 PM | #7 | |
Re: Adjust toe in
http://www.abarnyard.com/workshop/align.htm The instructions are still good for later cars and the identical tool is still available. Do a web search for "Duby Wheel Alignment Gauge" to find a supplier. Price in the $75 to $100 range. |
07-10-2011, 01:35 AM | #8 |
Re: Adjust toe in
I saved the 75-100 bucks and jerry rigged a broomstick with a pointer on one end and a yardstick on the other. How often are you gonna need this tool, anyway?
Alan |
07-10-2011, 04:31 AM | #9 |
Re: Adjust toe in
A newspaper under each wheel can make a poor man's rotating table. I do it with the wheels on the ground. Roll the car back and forth a bit before re-measuring.
07-10-2011, 08:58 AM | #10 |
Re: Adjust toe in
dick spadaro sells a nice one not expensive & can be used on any car old or modern
07-10-2011, 01:18 PM | #11 |
Re: Adjust toe in
Thanks, I used the spin the wheel method and it worked fine. Instead of chalk, I put masking tape around the OD of the tire and mark on it with a fine point pen.
07-10-2011, 02:51 PM | #12 |
Re: Adjust toe in
This same discussion is current on the EFV8 Forum. I'll concede that the best way is with wheels grounded, and I do like the newspaper idea for that. Supereal on the V8 site tells me i'm wrong with the 1/16" per wheel dimension. He used to work in a Dealership and used the Duby gage there, adjusting for 1/16" total, not per wheel. What's the concensus here on that, 1/16" total both wheels or per wheel?
Alan |
07-10-2011, 03:14 PM | #13 |
Re: Adjust toe in
up to 1/6 per wheel .I would use a tape measure with wheels on the ground to the centre tread front and back .Roll the car forward ,do it again .If your car tends to wander on the free way ,Tow it in a little .check tyre ware pattern ,
07-10-2011, 03:34 PM | #14 | |
Re: Adjust toe in
07-10-2011, 03:39 PM | #15 |
Re: Adjust toe in
It's better to use kitchen wax paper under the tires, but double and the wheels will reflect there true position. My my 2cents
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. Last edited by gmc1941; 07-10-2011 at 03:41 PM. Reason: more info |
07-11-2011, 01:29 PM | #16 |
Re: Adjust toe in
If the car ducks and dives & tracks chances are that its towed out ,If it gets tyre squeal when turning its towed in ,I think my car is towed in 3/32 s . it now tracks straight and true .
07-21-2011, 03:16 PM | #17 |
Re: Adjust toe in
Car needs to be on the ground. I drive in the shop and hit the brakes- center mark tires and measure distance front and rear put 1/8 toe in total then back out of shop and back in again and hit brakes and re check. If measured right you will be dead on the mark.
07-21-2011, 11:10 PM | #18 |
Re: Adjust toe in
I like to do them like this
On stands under the axle Wheels off Strait edges on the wheel mounting surface’s Marks on strait edges at tire diameter (front and rear) Simply run the tape across front and rear. I prefer this to trying to use the tire and its easier to do this way when your by yourself |
07-23-2011, 02:00 PM | #19 | |
Re: Adjust toe in
07-25-2011, 06:03 PM | #20 |
Re: Adjust toe in
A couple simple methods from stockcar land . First pic is 2 aluminum plates 2' x 9" with slit's for tapemeasures 3" up from the bottom on all 4 ends . Just lay against the tire so that the top edge is flush with the sidewall { 9" up gets above any sidewall bulging } and string two tapemeasures between . The long " C " shaped thing is really simple and is meant for doing it by yourself . The tab on top on one lays aginst the sidewall on the far side and you check the near end with a tape . Both setups are cheap,simple,easy to make & are totally accurate IF your stuff is straight . I can't get the pics through - sorry & I'll try later . Hearz da pics
