01-24-2013, 09:10 PM | #1 |
Need a little advice
Hello again,have been taking apart my 31 pickup for the last few weeks and now putting back together.This has been a lot more work then I ever expected but I'm having a ball!We are having a little trouble getting the gas tank and welt back properly.Is there a trick to this?
01-24-2013, 09:57 PM | #2 |
Re: Need a little advice
Many threads on this. Search the forum for "gas tank welt."
01-24-2013, 10:40 PM | #3 |
A few dabs of contact cement to hold the welt in place can be useful.
Dave
Dave / Lincoln Nebraska |
01-25-2013, 01:27 AM | #4 |
Two people sure help. I helped my friend do his 31 wide bed pickup and it took a few tries to get the welt pulled in tight and straight. I was inside the cab tightening the bolts while he was on the outside and pushed the welt into place and held it until the bolts were tight.
01-25-2013, 03:29 PM | #5 | |
When I experience "GAPOSIS" I use those little self adhesive round Velcro thingys to increase the thickness. I also use them at the ends of a welt, so's they don't EVER pull out when I wipe the car! Bill W.
01-25-2013, 10:37 PM | #6 |
01-25-2013, 11:25 PM | #7 |
I used some masking tape to hold it in place. I put the tank in place, punched holes for the bolts and then pulled the tape out before I bolted it down. Some of the tape did not come out but it was under the window sill so it did not show. Mine was a 1929 but I assume yours would be about the same.
01-26-2013, 02:01 AM | #8 |
Had a loose, slightly shrunk welt on an inside curve at the rear corner of the gas tank. Used a syringe & injected Regular Gorilla Glue, which foams to fill voids & taped it down until it dried. I first rubbed dusting wax on the exposed welt & adjacent paint so that any foam cam out, I could just fleck it off. This worked very well!
A dear friend & talented car builder will NOT use welt ANYWHERE! After his car is painted, he meticulously caulks & smooths the joints way back in. Then calls his pin striper & has him paint the caulking. It looks great as if it came new that way & no one pays any attention to it. Bill W.
01-26-2013, 09:17 AM | #9 |
I staple strips to the welting to pull it through. i believe this is in the les andrews repair book, it works well for me
