Old 10-01-2016, 12:19 PM   #1
flatman
flatman's Avatar
Default Solved......need help with carb linkage on 223ci 6 & fordomatic
This problem has been solved.........Having a heck of a time trying to figure out how to hook the carb and trans linkage up correctly. 223 ci with fordomatic in a 54 ford. If anyone could post a pic of the correct way, it sure would be appreciated. Just picked this car up and the linkage was kluged together.. heres a pic of what i am working with..Thanks again for any help...
flatman is offline   Reply With Quote
Old 10-02-2016, 07:47 PM   #2
y'sguy
y'sguy's Avatar
Default Re: Solved......need help with carb linkage on 223ci 6 & fordomatic
I used to have that linkage . You are missing quite a few parts there. I might first searching ebayfor some. I've seen it on there before although you may end op buying more stuff that you need.
y'sguy is offline   Reply With Quote
