Old 04-22-2020, 10:06 AM   #21
burner31
burner31's Avatar
Default Re: Good time to check your fan blades
Originally Posted by 160B View Post
Here are two photos. The first photo shows where the crack starts on the original two bladed fan. The second one photo shows the damage done to the cast iron water pump casting. I do not have photos of the damage done to the radiator and the hood.
Is that an aluminum fan?
Keith
Shawnee OK
'31 SW 160-B
Old 04-22-2020, 12:23 PM   #22
160B
160B's Avatar
NO it is not aluminum. It is an original two bladed steel fan. The aluminum fans are cast aluminum and thus they are solid.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-22-2020, 12:38 PM   #23
duke36
Concur with all about using the alum. fans. Have had them on 5 Model A's since inception.
Just removed an original steel 4 blade with blade hairline crack near the hub obscured by paint. I'd toss them also. I've never tried the plastic multiblades for a modified car.
Old 04-22-2020, 01:19 PM   #24
burner31
burner31's Avatar
Very different then mine, mine is a flat stamped blade
Keith
Shawnee OK
'31 SW 160-B
Old 04-22-2020, 08:00 PM   #25
Ray in La Mesa
In 1964 coming home from college in the Mojave Desert to Big Bear Lake about midnight in my1930 Fordor I heard a loud thump & emmdiate sever vibration. pulled over to look & found one of my four fan blades had disappeared. Couldn't find it in the dark so drove on home, about 5 miles. Next morning I looked again & found the blade sitting on top of the firewall mounted battery, between the terminals, no sparks! Guess I got lucky. In 1973 while driving my 1928 roadster pickup across the U.S. (9,000 miles & 7 weeks. Trip article in Model A News Vol. 20, iss. 6. Photo of p/u & trailer w/ sleigh at 1973 Dearborn meet Vol. 20, iss. 5.) my water pump started leaking antifreeze & pealing paint off the firewall. Pulled into a rest stop to change pump but couldn't get it off w/o pulling the radiator due to the 4 blade fan. I sat there for a while on the gas tank with my feet in the engine compartment contemplating my delimma. I finally decided to bend one blade back and changed the pump. A fellow in the audience said I couldn't do that, little did he know. Used my foot to push the blade back straight and drove 1500 miles home. I replaced the fan when I got home. A bit older & wiser now, I run the new aluminum fans.
Ray in La Mesa is offline   Reply With Quote
Old 04-22-2020, 08:24 PM   #26
Conaway2
Conaway2's Avatar
A year or so after I bought my first Model A in 1967, the fan blade separated at about 40 mph, and I’ll never forget how badly the engine vibrated after that. Fortunately the blade that separated left the engine compartment without doing any damage. I always inspected fan blades frequently after that, and, after owning a Model A for 52 years, finally installed an aluminum blade last fall. All my original propellers sit on my parts shelf looking pretty cool.
Conaway2 is offline   Reply With Quote
Old 04-24-2020, 04:59 AM   #27
Karl
Karl's Avatar
A few years ago I lost a blade on my four blade fan on my 34 Fordor .Goodness knows where it went but somehow exited the engine bay without punching a hole in anything. I was travelling at about 60 mph. The vibration lasted for about 10 seconds and then the inlet manifold cracked and dropped the generator and what was left of the fan into the radiator . Lots of water lots of steam and a ride home on a tow truck! On the fan I run now I've braised all the joints on it to hopefully stop a repeat.
On the A I've run an aluminium fan for 10 years -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is online now   Reply With Quote
Old 04-24-2020, 07:23 PM   #28
SSsssteamer
SSsssteamer's Avatar
Originally Posted by Tacoma Bob View Post
I have mentioned this for a long time. My first Model "A" fan flew apart back in 1968. That's 52 years ago. Go ahead and live dangerously.
I lost a fan blade in '68 also. I will never forget it. It not only ruined my radiator, but the out of balance fan also tore the water pump off of the block too. Sounded like a shot gun going off as the fan blade also went through my hood. I have had no broken blades since. I now know what to look for.
SSsssteamer is offline   Reply With Quote
Old 04-27-2020, 04:57 PM   #29
2935ford
2935ford's Avatar
Just did that with an aluminum blade.
2935ford is offline   Reply With Quote
Old 07-24-2023, 01:20 PM   #30
oak29
I had the fan blade shear and rip into the rad on my '28 Phaeton recently; rad recored and up and going again. I've had to use a new 2 blade fan as a replacement but don't want to leave long term. Usual stockists are out of stock of the 2 blade aluminium type.
Any ideas where I can get a reputable new aluminium one from? (I live in UK but can get stuff shipped via my son who lives in NYC).
oak29 is offline   Reply With Quote
Old 07-26-2023, 09:28 AM   #31
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Berts: www.modelastore.com/
Snyders: www.snydersantiqueauto.com/
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-27-2023, 01:52 AM   #32
Randy in ca
Randy in ca's Avatar
Originally Posted by BRENT in 10-uh-C View Post
Both of those plus everywhere else I've checked they're currently out of stock
Randy in ca is offline   Reply With Quote
Old 07-27-2023, 02:28 AM   #33
TomInCologne
TomInCologne's Avatar
...out of stock since the four fan-related threads in this forum were opened?
TomInCologne is offline   Reply With Quote
Old 07-27-2023, 04:03 AM   #34
mercman from oz
mercman from oz's Avatar
Apparently, these Fan Blades come adrift more often that you might think.
This one happened on the Model A Run in New Zealand this year.
Old 07-27-2023, 06:05 AM   #35
BRENT in 10-uh-C
In a July 12th email that Don Snyder sent, he said that he had received confirmation on the 11th that fans were due in 2 weeks. The math would indicate that they should be there now, -or very soon.
BRENT in 10-uh-C
Old 08-25-2023, 04:54 AM   #36
oak29
Just to wrap this up, Synders have now got in a new stock of fans (they told me 1,000!). I've just received delivery of mine from them and will fit it when I drain the system down to replace anti-freeze for winter. Thanks for the useful advice.
Old 08-25-2023, 05:55 AM   #37
[email protected]
My 2 blade original fan came apart last week, dented the hood and I found the blade on top of the throttle linkage , I replace it with a new cast aluminum blade new water pump, belt, upper radiator hose was cut and leaking and the crank pulley was warped also, The original blade showed no signs of cracking prior so just an FYI change out the old blades out of precaution as someone could have been hurt or killed,
Peter
pwalk6270@gmail.com is offline   Reply With Quote
