11-01-2014, 04:18 PM | #1 |
29 Tudor door alignment...Not good
Before I took the body of of my 1929 Tudor, the door moulding ligned up real good with the quarter panel moulding, both right and left.
Now that I have put the body back on the chassis, using all the original body pads, the doors now droop down about 1/8 inch. What must I do to reposition the doors (raise them) so as to get the door and quarter panel mouldings to line up? In other words, at what point on the chassis would raise the doors to the correct level? Thanks. Pluck Last edited by Steve Plucker; 11-01-2014 at 05:30 PM. |
11-01-2014, 04:52 PM | #2 |
Re: 29 Tudor door alignment...Not good
You need to add shims. Either metal body shop shims or you can add thin wood strips until the doors line up. I went through the same problem with my 28 sport coupe last year. It took more shims than I anticipated but it worked out well.
Jim |
11-01-2014, 04:55 PM | #3 |
I had to bend / straighten the hinges a little on my coupe the doors fit good now .
Dennis in Kelsey ca Last edited by Dennis Pereira; 11-01-2014 at 05:00 PM. |
11-01-2014, 05:01 PM | #4 |
11-01-2014, 06:01 PM | #5 |
Same as on a coupe I bent the hinges on the door with heat and a pipe wrench with a cheater . They were also bent out so there was a big gap and would spring back when closed .
Dennis in Kelsey ca |
11-01-2014, 06:45 PM | #6 |
11-01-2014, 07:01 PM | #7 |
11-01-2014, 07:15 PM | #8 |
My right door on my 29 Tudor must have a bent hinge because the door starts to flex when the door is about 2" from being closed. I haven't tried to fix it yet, but I know I can't bend the hinge by using a socket and closing down on it, as I've done on modern cars.
11-01-2014, 07:51 PM | #9 |
an 1/8th in is not much... once you have your dovetails and door bumpers installed it will be fine......i wouldnt bend, heat or shim anything
11-01-2014, 08:05 PM | #10 |
To raise the door at the rear to align the body molding, either remove a shim at the very front bolt where the cowl bolts to the frame or add a shim under the area heer the hinge post or coupe pillar where the cowl bolts to the frame. What probably caused the problem is when you reinstalled the body, the bolt at the rear of the cowl got tightened more squeezing down the rubber shim-pad more or the front cowl bolt wasn't tightened as much.
11-01-2014, 08:16 PM | #11 | |
Did not remove the door bumpers OR the dovetails...they staid on the body as is. Pluck Last edited by Steve Plucker; 11-01-2014 at 08:22 PM. |
11-01-2014, 08:21 PM | #12 | |
Pluck |
11-01-2014, 08:29 PM | #13 | |
11-01-2014, 08:56 PM | #14 |
Purdy's got the right answer... As usual.
11-01-2014, 09:13 PM | #15 |
Marco has an article on his site about body shims for door alignment. The example is a Fordor but the principle is the same: http://abarnyard.com/workshop/door-1.htm
11-01-2014, 09:20 PM | #16 | |
Pluck |
