Old 08-22-2016, 03:13 PM   #1
Fred K-OR
Fred K-OR's Avatar
Default Motor installation with float a motor mounts
Just a simple question about when a person re-installs an engine with float a motor mounts. Question is: Do you mount the upper part of the FAM before you lift the engine in or do you put them on once you get the engine lifted in place and you are ready to bolt them down? Hope this makes sense. I was just concerned about getting the engine around the steering column with the upper FAM bracket in place on the engine when moving it in.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-22-2016, 03:21 PM   #2
duke36
Default Re: Motor installation with float a motor mounts
found it easier to remove the upper FAM on the driver's side to clear the column, then
re-install.
Old 08-22-2016, 04:09 PM   #3
Fred K-OR
Fred K-OR's Avatar
re-install.
Thanks Duke36. This is what I was assuming would be a better way to go, not having any experience with FAM stuff.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 08-22-2016, 05:00 PM   #4
CarlG
CarlG's Avatar
A little off the original topic, but IF I were to purchase FAM's, do all the vendors sell the same one, or are there differences in them?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-22-2016, 06:44 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Carlos,
Some are ALUJIMUM & some are CAST IRON One dealer gives you your choice. (DECISIONS-DECISIONS!)
Bill W.
"THE ASSISTANT GURU OF STUFF"
