06-10-2016, 07:40 PM | #1 |
Brake lathe
does anyone here know what make and model lathe that will turn rear drums for model A?
Thanks |
06-10-2016, 08:04 PM | #2 |
Re: Brake lathe
We had a Sunnen Brake Drum Lathe, but found it easier to do the job with an ordinary machine shop engine lathe
06-10-2016, 09:39 PM | #3 |
Re: Brake lathe
I have an Ammco Brake Lathe that does a good job on front and rear model A brake drums. I have done quite a few for club members over the years. I have seen them for sale occasionally on e-bay and even on Craigslist a few times. Don/WI
06-10-2016, 09:59 PM | #4 |
Re: Brake lathe
Ammco will if you install the 11/16" spindle.
Bob |
06-11-2016, 01:06 AM | #5 |
Re: Brake lathe
Correct
Here is the info you need for the aamco http://fordbarn.com/forum/showthread...ght=rear+drums |
06-11-2016, 02:10 AM | #6 |
Re: Brake lathe
06-11-2016, 07:44 AM | #7 |
Re: Brake lathe
The Barrett/jim beam works well, the adapter you can see on the left top fits in the rear wheel bearing so the seal doesn't even have to be removed
06-11-2016, 02:34 PM | #8 |
Re: Brake lathe
06-11-2016, 09:11 PM | #9 |
Re: Brake lathe
Thanks fellow's !
