Old 11-29-2010, 10:46 AM   #1
54bomb
54bomb's Avatar
Default Fuel guage removal
Im trying to get the fuel guage out of the stock tank on my 30 coupe. Its been in there a while and I didnt want to force it or break it. Im assuming the bezel twists off some how? I did a search but didnt come up with anything. Thanks !
54bomb is offline   Reply With Quote
Old 11-29-2010, 10:52 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Fuel guage removal
It is best to use the two tools available from the suppliers of a local club "tool crib" to remove and replace the guage. The outer nut holds the guage in place and frequently is tight but will come off with the proper tool. A large socket will most likely work as well, just be sure it fits well and is held very tightly against the nut when being turned. The nut does have right hand threads. Gar Williams
Aerocraft is offline   Reply With Quote
Old 11-29-2010, 10:54 AM   #3
54bomb
54bomb's Avatar
Right hand threads.. thanks, I never would have guessed that.
Old 11-29-2010, 12:19 PM   #4
dmaxweb
dmaxweb's Avatar
Right Hand Threads = Right to tighten/Left to loosen (normal thread)
dmaxweb is offline   Reply With Quote
Old 11-29-2010, 12:47 PM   #5
54bomb
54bomb's Avatar
oh right , sorry
Old 11-30-2010, 07:04 AM   #6
A-Jay
A-Jay's Avatar
Borrow or even buy the two tools ,they are cheap and there are a few different designs but they will work much better than using your every day tools. When you put it back together you should use new gaskets cork or neoprene. If your crome peices (2) around the little window are discolored this is the time to replace them while its apart. 18-25 bucks tops for all,
A-Jay is offline   Reply With Quote
Old 11-30-2010, 09:03 AM   #7
1931 flamingo
1931 flamingo's Avatar
Make sure while it's apart you ck the float, if cork you might want to replace with new style which isn't (so far) affected by the new gas. Also some say cork gskt superior to the neoprene.
Paul in CT
Old 11-30-2010, 10:07 AM   #8
Bruce Adams
Bruce Adams's Avatar
A little lacquer thinner will disolve eighty years of dried up gasoline if it doesnt turn easily.
Be careful it doesn't run down the dash board.
Bruce Adams is offline   Reply With Quote
Old 11-30-2010, 12:19 PM   #9
1931 flamingo
MAKE SURE YOU DISCONNECT BATTERY BEFORE REMOVING DASH PLATE !!!!!!!!!
pAUL IN ct
Old 11-30-2010, 03:05 PM   #10
54bomb
54bomb's Avatar
Thanks, I wish I was the stage of this build where I had a battery connected
This tank hasnt had fuel in it or electricty through it in decades. I appreciate the help guys.
Old 11-30-2010, 05:51 PM   #11
Don/WI
If you use someones tools or decide to buy a ste, steer clear of the ones made of aluminum. They oftentimes slip off and do more harm than good. Bratton's has a set of steel tools (#13520) for $8.40. I'm sure other suppliers have them also. Don/WI
Don/WI is offline   Reply With Quote
Old 11-30-2010, 10:40 PM   #12
B0B
YES DON ! I agree just changed my gauge glass it was very foggy and you could not see the numbers at all ... Seems someone had worked on it before years ago and replaced it with a plastic "Glass" piece ...You can tell these right away they have a little built in magnifying lens in front ! If you have one with the magnifying lens and find it is plastic ( try to scratch it with a pen knife ) replace it before the ethanol in our modern gasoline fogs it up or worse eats it right out ...Anyway I bought the STEEL tools and had no problem replacing the lens ...I used the neoprene gaskets and neoprene float and sure hope they hold up ok ...Now I can see how much gas is in the tank !
B0B in Michigan
B0B is offline   Reply With Quote
Old 11-30-2010, 11:35 PM   #13
John Butts in CT
John Butts in CT's Avatar
Hold on, Bob. Speaking from (painful) personal experience... original style varnished cork gaskets outlast neoprene when exposed to E10. Our friends in NZ and OZ also suggest adding molasses to the gaskets, but that may just be a southern hemisphere thing I keep a couple of sets of varnished cork gaskets on hand. It's a quick job to replace all of the gaskets, and (to my mind) far preferable to finding black goo obscuring the gas gauge.
John Butts in CT is offline   Reply With Quote
Old 12-01-2010, 08:51 AM   #14
1931 flamingo
In previous posts on this subject maple syrup was suggested as a lubricant. FWIW
Paul in CT
