09-22-2010, 01:07 PM | #1 |
Schrader 888 tire valve
What is the thread size (ID) of the Schrader 888 valve stem? I had a set of 5 originals nickel plated and now there is a slow leak in 2 of them (they held fine before plating). I assume this is the result of the threads of the internal valve gizmo not seating properly on the new plating. Thought I would chase the internal threads and see it that helps. The internal gizmos are new so that could be a source of problem as well but was afraid the originals would have dry rotted.
09-22-2010, 07:05 PM | #2 | |
Re: Schrader 888 tire valve
