01-23-2022, 12:08 PM | #21 | |
Re: 8BA Compression Test - Is it worth and an engine strip down?
You might check your accel pump and see if it is squirting correctly (do it with the engine not running first!). It can also be timing . . . |
01-23-2022, 02:14 PM | #22 |
Is that the way they were designed?? Just another excuse to grab your honeys leg by “mistake”.
Cheers, Jim&Sandy McGregor, IA |
02-03-2022, 02:39 AM | #23 |
02-03-2022, 02:43 AM | #24 | |
Good thought. |
02-03-2022, 09:30 AM | #25 |
I wish my 8BA had those numbers. I'm still driving it but my numbers are way lower then yours. If it wasn't for the smoke billowing from under the hood and low to no oil pressure I would leave mine alone. I say let it roll and enjoy it. Tim
