09-18-2015, 10:09 PM | #1 |
distributor
for you guys still fighting with the helmet dist, Speed Way makes a cam gear cover that lets you run a 49 dist on the earlier engines
09-18-2015, 11:12 PM | #2 |
Re: distributor
I would think the 49 and later distributor would be a lot harder to deal with than the front mount unless you were going to the chevy converted distributor. You would have to use the carb that matched the distributor for the stock set up and you would have to establish a timing mark. With all of that I would still think it is a poorer distributor than the dual point front mounts.
09-19-2015, 04:55 AM | #3 |
Re: distributor
I think anyone entertaining this kind of change would also be the type to go to an updated distributor rather than a "Load-a-matic". I'm sure Speedway would be glad to sell you a matched set (with a Chevy advance curve, of course). What do they use for a drive gear? I would think they would have to offer it as a complete system.
(Edit : This intrigued me, so I went to the Speedway site and can't find it; do you have a link or maybe a part number?) Last edited by tubman; 09-19-2015 at 05:02 AM. |
09-19-2015, 07:36 AM | #4 |
Re: distributor
That 8BA adapter for the front of the 59ab cam is no big deal, I made one for a 58ab 276 in my 40, just bolt on an 8ba front cover, make a place for the set screw to lock the dist, I used an old 8ba style malory 2 part cap dist on mine. I think there is a pic it in Speedway cat, I havevn't got time to look to look. Walt
09-19-2015, 08:39 AM | #5 |
Re: distributor
I can not understand why anyone would have to "fight" the helmet distributors--I believe they are wonderful and work best on the early flatheads--Also easy to have a spare set up and ready to go--Just unbolt the one and install the other--No messing with a timing light either--
09-19-2015, 08:45 AM | #6 |
Re: distributor
09-19-2015, 06:20 PM | #7 |
Re: distributor
tubman, a pic of it is on page 274 of speedways catalog #502
09-19-2015, 08:38 PM | #8 |
Re: distributor
See here----
http://www.speedwaymotors.com/Offenhauser-Flathead-Ford-Early-to-Late-Drive-Gear,25039.html http://www.speedwaymotors.com/Offenhauser-Flathead-Ford-Timing-Cover,25038.html
09-19-2015, 09:45 PM | #9 |
Re: distributor
Helmet, crab or 46-48 distributor is superior in my opinion to a 49-53 loadmatic. Would never make that switch.
