05-04-2019, 09:45 PM | #1 |
Overdrive
I have a 49 4door custom all stock. Can I put an overdrive with my existing tranny or will I need a different transmission?
Sent from my SM-T550 using Tapatalk |
05-05-2019, 05:59 AM | #2 |
Re: Overdrive
You can’t simply “add-on” the Borg Warner overdrive unit to an existing Ford straight 3 speed transmission. There are numerous fundamental differences in the gearbox and the transmission main shaft that prevent you from trying this modification.
There are still many 1949-50 Ford overdrive transmissions out there. Buy one as a core and have it rebuilt. Everything still bolts up the same as your regular 3 speed, including the driveshaft. A 1951 Ford OD trans will also work, but will require a modification to the rear support to fit.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
05-05-2019, 08:06 AM | #3 |
Re: Overdrive
OR
Just buy it from Mac, I know for sure he's got some. There are snares in these OD's, that can get overlooked. A worn out planetary is not uncommon & uncomfortably pricey. Solenoid, governor, kick down switch, firewall mounted relay and the cable are all part of the equation. It is worth it for sure ! Charlie ny |
05-05-2019, 08:48 AM | #4 |
Re: Overdrive
Thanks I didn’t think it was an add on to existing tranny.
Sent from my iPhone using Tapatalk |
05-05-2019, 12:10 PM | #5 |
Re: Overdrive
