02-05-2012, 09:13 AM | #1 |
Weidenhoff distributor machine.
I just picked this up from one of my dads old friends who`s 80 and wants to clean out his old shop he started in 1952, and i`ve made a deal on most of the important stuff.
He bought this as his first dist machine and used it up to around 1962, when he upgraded. It is no doubt prewar, and something tells me around late 20`s early 30`s. He beleives he has the litterature for it somewhere but it`s been 50 years so.. It is very neat and i need any info i can get on it. Any others on here who`s into old machines like this? |
02-05-2012, 09:21 AM | #2 |
Re: Weidenhoff distributor machine.
Neat Contraption. How is it used?
02-05-2012, 11:06 AM | #3 |
Nice score. I like old machines like that. I think it would be neat to set up an antique shop, complete with a line shaft run by an antique motor.
BTW, I'm still looking for bits to fit my old Weidenhoff generator/starter pole shoe remover. |
02-05-2012, 12:11 PM | #4 |
I have a Weidenhoff Starter/Generator/Magneto machine. I have never seen another like it or been able to find any literature on how to operate it.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
02-06-2012, 02:55 AM | #5 |
The Distributor is held by its pilot diameter by the clamp on the stand behind it, the distributor is driven by its drive by the chuck and i can run the distributor in all kinds of speeds shown by the tachometer, with a slider speed adjuster and even a below idle slow button on the right, There is also a switch for rotation direction.
The spark will go between the pointer directly down to the 360 degree scale under it. Allowing you to mark the scale with a mild marker and measure cam angle (charge time), cam symmetry and advance at different speeds. From what I understand there is an internal coil and also condensers, so hooking it up should be easy. I will change some wires before I plug it into the wall and try it on a known good distributor. The small base under the degree plate is cast or forged into one piece and holds gear oil for the small angle gears inside. I need to dive into this machine one of these days and get it working. |
02-06-2012, 05:55 AM | #6 |
One key ability of these machines is in checking/adjusting/modifying the advance of distributors that automatically regulate the spark advance. The advance can be checked at various rpm's to provide the desired performance. Another function that is normally built into the later machines is a dwell meter. I cannot tell if your machine includes that. Appears not. Adjusting the dwell more accurately with a mechanical distributor becomes more critical with more cylinders. With more cylinders to fire in a 360 degree rotation, the coil saturation time must be managed better. Very nice machine. A prize. Thanks for posting it. (Here is a YouTube video of a later model Sun) https://www.youtube.com/watch?v=2kf9i...eature=related And another older Weidenhoff:
"Remember that when it comes to intelligence, half of all of us are below average." Last edited by Hoop; 02-06-2012 at 08:40 AM. Reason: Added video |
02-06-2012, 12:22 PM | #7 |
Weidenhoff became Sun.
02-06-2012, 12:36 PM | #8 |
02-06-2012, 09:06 PM | #9 | |
I can't give you the exact history. I learned that when I toured the Snap-on Tool Company in Milwaukee back in the '90's. Snap-on also owns Sun. http://articles.chicagotribune.com/1...otive-industry
02-07-2012, 07:04 PM | #10 |
I love vintage shop equipment! A while ago I posted a question about a piece of equipment that I have. It’s a Simpson model GRT, Generator Regulator Tester. I don't have a pic because I'm out of the country, but it is speckled black and white with Red lettering for the moniker and other labels. It does not have a 110 plug. My question is, would any of you gentlemen know how to get an owner’s manual and or how to use it? Here is the link to my previous thread and the responses I got that didn’t yield anything.
https://www.fordbarn.com/forum/showthread.php?t=40853 |
11-10-2014, 05:10 PM | #11 | |
When the Chrysler wedge engines were popular I used it to do tune ups because it was easier to pull the distributor than try to work on it on the engine. It would only go back in one of two positions because the gear drive was on the oil pump so it was very easy to remove and install. The distributor machine also allowed you to set the individual points correctly on dual point systems as you could block one set of points and set the other. I also used it for shaving mechanical advance weights for racing engines. Until the introduction of the electronic ignition systems (pointless) the machine was a regular part of my shop equipment and used frequently. Basically the operation of the machine is very simple and straightforward. |
11-10-2014, 05:29 PM | #12 |
Eightdogs, if you spray that machine with WD-40 and wipe it off with a soft cloth it will make a big improvement. I haven't seen any distributor machines at swap meets for the past few years.
11-11-2014, 12:21 PM | #13 |
here is a nice old weidenhoff mica undercutter. $25 at a swap meet, in great condition. repainted original color, new cord, new belt, works great. this thing is a work of art. lot of machinery just to cut mica.
11-11-2014, 02:17 PM | #14 | |
I'd Love to have for Mica clean up repairs. I have a Sun Growler. Great Find even at Triple the price you paid! |
11-11-2014, 10:52 PM | #15 |
It is a lathe. It also turns the surface of the armature.
11-12-2014, 11:02 AM | #16 |
no, it is not also a lathe. wish it was.
11-13-2014, 01:15 AM | #17 |
Actually Jos. Weidenhoff co. was purchased by Bowser Co. after WWII in Algona, Ia. Weidenhoff name was kept and they operated in Chicago on Roosevelt road ( building still stands today) and in Algona, Ia. Snap on purchased Weidenhoff in the 1950's. Weidenhoff was and still is for the older stuff the Cadillac of test equipment. Their old magnet chargers are sought by Model T Ford boys for recharging magnets and on the internet command big dollars. The 701 Weidenhoff growler is exceptional and makes many tests on armatures. The featured early synchrograph or distributor tester is from 1920's. No ability to test any sort of vacuum advance tests or vacuum brake on V-8 distributors. The Sun distributor machines could be had 15 years ago for reasonable money, not so much now. Prices are almost unrealistic on EBay. The 1950's up to 1960 always required a 6 volt battery in back for ignition power and 2 D cell batteries to powerup dwell meter. When the 12 volt versions came out a battery charger was included to keep rear battery charged. It is best to purchase a 500 series or 600 series machine as the rear battery was eliminated. You can also find an adapter to test electronic distributors.
11-13-2014, 01:24 AM | #18 |
Tom, Tried to send you a PM, but your mail box is full. Wow you are popular.
11-13-2014, 09:04 AM | #19 |
11-13-2014, 10:49 PM | #20 |
Tom, I also have a Weidenhoff pole shoe scre remover/replacer but didn't get the ratchet with it. If you give me the physical rectangular dimensions of the holder I can machine some up out of A-2 tool steel and heat treat them. Then I can grind either the screw slot width or square head shape on the bits. Let me know.
