07-26-2019, 02:02 PM | #1 |
Snap Gap Tool for 312
Does anyone know where I can find a snap gap tool for setting the points on a 312?
07-26-2019, 05:44 PM | #2 |
Re: Snap Gap Tool for 312
If you GOOGLE, you will find old sets.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-27-2019, 01:06 AM | #3 |
Please enlighten us that are ignorant of this tool. Won't a regular point setting tool work?
07-27-2019, 03:13 AM | #4 | |
The tool has hollow sleeves that slide over the dist can so as you don't need to move to high point of cam. Saves a lot of time and sweat, especially if one specialized in engine tune before electronics.
07-27-2019, 09:48 AM | #5 |
They were fast and accurate.
07-27-2019, 10:00 AM | #6 |
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria Last edited by Anteek29; 07-27-2019 at 11:17 AM. |
07-27-2019, 10:26 AM | #7 |
So if my thinking is correct you slip the sleeve over the cam and alter the gap to compensate for the sleeve and not have to crank engine? I would think dwell meter was better but would take considerable longer.
07-27-2019, 04:35 PM | #8 |
The GM stuff was easy to adjust for dwell. On the Fords, I set them to gap with a wire gauge and checked them with the dwell meter. I seldom ever had to adjust the dwell. When I did, it was usually because of a misalignment of the two point faces or a worn out bushing in the distributor body.
07-28-2019, 01:07 AM | #9 |
Thanks for the education. When I use the term "ignorant" it basically mean unknowing or unaware, definitely not stupid.
07-28-2019, 02:01 AM | #10 |
Just affirming ...
08-13-2019, 09:47 AM | #11 |
Thanks for input everyone.
