Old 07-11-2015, 08:19 AM   #1
1929
Default Running board splash aprons
can the aprons be removed easily without taking the body off frame?
1929 is offline   Reply With Quote
Old 07-11-2015, 11:01 AM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Running board splash aprons
"Easily" that is the key word...you can do it but NOT easy!
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 07-11-2015, 11:07 AM   #3
ericr
ericr's Avatar
in my experience with a '29 roadster, you would have to raise the body slightly though not remove the body. the apron is held on at the back by a small carriage-head bolt and certain body blocks sit on the apron. of course you would have to loosen various connections such as the body bolts, rear fender to running board bolts, steering column bolts, gas line, etc.
ericr is offline   Reply With Quote
Old 07-11-2015, 03:37 PM   #4
Mitch//pa
It's not bad to do. Loosen up the body bolts enough to get enough clearance to the apron to frame mounting hardware. About an inch
