Old 06-10-2016, 07:40 PM   #1
loubob
Default Powergen Alternator Install Problem
I am helping a friend install the above alternator in his car.
43" belt won't fit.
44" one does but the alternator hits the lower radiator pipe when tightening it.
How can we keep it from hitting the lower pipe?
Is there a 43 1/2" od belt available?
Thanks.....Loubob
loubob is offline   Reply With Quote
Old 06-10-2016, 08:16 PM   #2
Glenn C.
Glenn C.'s Avatar
Default Re: Powergen Alternator Install Problem
You should use a cog or segmented belt to allow the belt to ride down correctly in the pulley. This helps to pull the belt away from the lower pipe.
Glenn C. is offline   Reply With Quote
Old 06-10-2016, 10:31 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Give the supplier a call to see what they recommend.
On a stock Generator I remove the pulley, place the belt in the pulley groove and remount the pulley. This will allow you to use the smaller of the two belts you have tried. I've don't have any experience with the alts that look like generators to give definitive answers.
Old 06-11-2016, 08:23 AM   #4
Ray in La Mesa
If your alternator has the "shackle like" bracket with two bolts, the bolts are both pivot points so you could rotate the bracket to a more vertical position to clear the lower hose.
Ray in La Mesa is offline   Reply With Quote
Old 06-11-2016, 09:08 AM   #5
Bruce Adams
Bruce Adams's Avatar
In support of Ray, make sure the bolt going through the alternator is loose as that bracket can be swung around permitting lots of adjustment and fitting distances beyond the rotational one provided by the bolt at the engine.
How does your Powergen's pulley line up relative to the water pump's and the crank shaft's pullies?
Bruce Adams is offline   Reply With Quote
Old 06-11-2016, 10:40 AM   #6
katy
katy's Avatar
Like this? https://www.summitracing.com/int/par...view/make/ford
Old 06-11-2016, 10:55 AM   #7
rscardina
rscardina's Avatar
I had some difficulty getting my belt back on when I installed my Powergen. I worked the belt on and tighten down on the mounting bolts. The belt wasn't too tight and it runs fine. You might want to force the smaller belt on and try it. From what I have heard is the belts need to be a little tighter on the alternator than on the generator anyways.
Ryan Scardina
Livingston, Louisiana
1930 LSU Model A
rscardina is offline   Reply With Quote
Old 06-11-2016, 09:25 PM   #8
loubob
Yes to Katy.
We have a 43 1/2" cog belt on order to try. Top width of belt is 1/2".
44" Dayco a little loose. 43" Dayco a little short.
Shackle bracket won't work according to a club member that sells 'A' parts for years.
If ordered belts don't work, will try Mike V's suggestion & Ryan S. suggestion
*****Ryan: What belt # did you use?? Outside width and o.d. length please.
Ordered belts arrive on Wed.
Will advise on outcome.
Thank you all.
Loubob
Old 06-11-2016, 10:42 PM   #9
rscardina
rscardina's Avatar
I will let you know tomorrow.
Ryan Scardina
1930 LSU Model A
Old 06-11-2016, 11:16 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Loubob, the belt should be 5/8" wide, not 1/2", unless you've change the pulleys.
Old 06-12-2016, 07:59 AM   #11
Dollar Bill
Dollar Bill's Avatar
As I've never seen the Powermaster alternator, does it look like the OEM generator so far as dimensions? May be camera angle but the Summit photo makes it look shorter than the original generator.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 06-12-2016, 10:45 AM   #12
rscardina
rscardina's Avatar
I measured my belt to be 43" od as it sits installed and width of 5/8".
Ryan Scardina
1930 LSU Model A
Old 06-12-2016, 11:17 AM   #13
George Miller
George Miller's Avatar
How about if you loosen the water pump bolts.
George Miller is offline   Reply With Quote
