Old 05-28-2013, 01:03 PM   #1
Houston Rodder
Houston Rodder's Avatar
Default Oil Leak Help?
My Fordor Sedan has an oil leak that is getting worse. The leak is very bad right after the motor has been run and slows after it cools off. What are some typical types of oil leaks these engines develop? I am wanting to have everything I need to fix before the vehicle is tore down although I realize it is impossible to know before pulling the pan. Besides a pan gasket what are some pieces I should inspect or replace with the oil pan off?
Thanks
Houston Rodder is offline   Reply With Quote
Old 05-28-2013, 01:30 PM   #2
sethkestenbaum
sethkestenbaum's Avatar
Default Re: Oil Leak Help?
I recently resolved the oil hemorrhaging on my 1929 by dropping the pan, removing the valve cover and cleaning out all the passageways including the oil return pipes. I wasn't expecting all my oil leaks to go away, but they did. A clogged oil return apparently is one of the big causes of leaks.
With the pan off, you may want to do an overhaul on your oil pump (which comes our when you drop your pan and requires an occasional screen cleaning and change of gaskets -- this is EASY albeit messy) and check bearing clearances (you can access the rod and main bearings with the pan down and make some adjustments if needed). I documented my trials and errors in dropping the pan (including some video and photos) on my blog and recently posted MANY questions on fordbarn. I am no expert, but am happy to share my experiences.
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 05-28-2013, 02:09 PM   #3
Houston Rodder
This is really helpful information. Thank you.
Old 05-28-2013, 08:36 PM   #4
Duffy1
Please specify the location of the leak .
Duffy1 is offline   Reply With Quote
Old 05-28-2013, 08:53 PM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
as said above, we need to know from where the leak originates to offer any constructive help. For that matter, so do you. Many leaks are from the valve cover, and they run along the pan rails and drip off the rear flywheel housing, giving the appearance of a rear main leak. The oil pan can leak in similar fashion. Then there are leaks from excess crankcase pressure, a missing oil return tube, clogged oil pipe, etc etc
this article is a good one for starters:
http://www.antiqueenginerebuilding.c...RMAINLEAK.html
pat in Santa Cruz is offline   Reply With Quote
Old 05-28-2013, 10:15 PM   #6
Houston Rodder
The leak is between the engine and the bell housing. If it was a sbc I would guess rear main seal.
Old 05-28-2013, 10:18 PM   #7
700rpm
700rpm's Avatar
I don't know what an sbc is, but that would be a good guess on a Model A too. But you can hope it is similar to Seth's problem.
Ray Horton, Portland, OR
Old 05-28-2013, 10:23 PM   #8
Duffy1
Is it dripping off of the carter key ? If so it is probably the rear main and/or leak from back of cam shaft . If it is coming down the front of the fly wheel housing it may be leaking from the pan gasket or from the front seal running down the pan and dripping off the housing plus what pat in sana cruz mentioned .
Old 05-28-2013, 10:38 PM   #9
Phil
Phil's Avatar
Most rear main oil leaks on a model A are due to too much clearance on the rear main. Drop the pan, remove the rear main cap inspect the Babbitt, if it is intact use palsti gauge to check the clearance. Should be about one and a half thousandths. If it is greater remove shims to get the one a half thousandths. Then check the center and front mains. All should be well when the pan is reinstalled.
Phil is offline   Reply With Quote
Old 05-28-2013, 10:54 PM   #10
Bob C
Also check the crankshaft end play, to much and it will leak.
Bob
Old 05-28-2013, 11:35 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Small Block Chevy
Old 05-28-2013, 11:59 PM   #12
Hicktick
Hicktick's Avatar
What mark are you using on your dipstick ???
You could be over filling it .
It will spit out what it don't want .
Hicktick is offline   Reply With Quote
