Old 12-28-2017, 12:37 PM   #1
rowens55
rowens55's Avatar
Default My new Y-block
Merry Christmas folks! Got my New engine installed over the holiday weekend. Haven't fired it yet but IMHO it looks fantastic nestled in the bay. What do you think? 304 ci, 304 hp, 330 tq. 11" clutch with a T5.
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 12-28-2017, 12:51 PM   #2
Oldmics
Default Re: My new Y-block
Looks like a fun ride.
Tell me - Did you use a hoist to install the engine or just your brute strength as in the holding the engine above your head picture ?
Oldmics
Oldmics is offline   Reply With Quote
Old 12-28-2017, 01:33 PM   #3
rowens55
rowens55's Avatar
That's my son-in-law and he IS a brute!! However it's hanging from a fork lift! Just a fun pic I thought I'd share.
Old 12-28-2017, 01:42 PM   #4
scicala
scicala's Avatar
Looks great Rowen ! Probably easier to tune than the two teapots too. Lol.
Sal
scicala is offline   Reply With Quote
Old 12-28-2017, 01:50 PM   #5
rowens55
rowens55's Avatar
Thanks Sal. Since the sale of those fell through I have decided to keep em and someday put em on. At least to see how she runs with em. Gotta get her up n runnin first as is.
Old 12-28-2017, 08:10 PM   #6
KULTULZ
KULTULZ's Avatar
Thumbs up Re: My new Y-block
LOOKS GOOD!
Can you describe the build... 292?
Who makes those headers? They look good also.
Why green?
What year/series 8V do you have? I have not been following.
Your Son-In-Law looks exactly like my brother...
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 12-28-2017, 08:18 PM   #7
scicala
scicala's Avatar
OK Rowen. I assumed you sold the Holley 4000's since I saw the add marked sold.
KULTULZ : The carbs Rowe has are two 1956 Ford Holley 4000 teapots (single 4V carbs) that I restored and set up for a dual 4 barrel engine.
Sal
Old 12-28-2017, 08:26 PM   #8
Kahuna
Kahuna's Avatar
Beautiful, Rowen
Jim
Kahuna is offline   Reply With Quote
Old 12-28-2017, 08:41 PM   #9
KULTULZ
KULTULZ's Avatar
Sal
OK.... THANX! for that info...
Old 12-28-2017, 09:16 PM   #10
rowens55
rowens55's Avatar
KULTULZ, it's a date Code 1957 312 sleeved down to a stock 292 bore. stock 312 crank and rods. 10.5:1 forged domed probe (Mummert) pistons. Clay Smith 292S cam. Mummert 4v dual plane aluminum intake with a edelbrock 600. I bought the engine as a abandoned project a couple years ago. The headers are REX performance. As close to a "true" header that I could find. They are a very tight fit but went in mounted without scratching anything. John Beck in Chico did all the machining and assembly. This car ought to ROCK!! It's my retirement gift to myself. Thanks Jim. Your place will one of my first stops when I get her on the road. And you Sal are not off the hook yet,...as I said, those WILL go on in the future and I will be giving you a holler when it happens.
Old 12-28-2017, 09:21 PM   #11
rowens55
rowens55's Avatar
Oh, and the green....my family will tell you I'm a quarter bubble off plumb so...just because.....is the best I got.
Old 12-28-2017, 10:28 PM   #12
KULTULZ
KULTULZ's Avatar
KULTULZ, it's a date Code 1957 312 sleeved down to a stock 292 bore. stock 312 crank and rods. 10.5:1 forged domed probe (Mummert) pistons. Clay Smith 292S cam. Mummert 4v dual plane aluminum intake with a edelbrock 600. I bought the engine as a abandoned project a couple years ago. The headers are REX performance As close to a "true" header that I could find. They are a very tight fit but went in mounted without scratching anything. John Beck in Chico did all the machining and assembly. This car ought to ROCK!! It's my retirement gift to myself. Thanks Jim. Your place will one of my first stops when I get her on the road. And you Sal are not off the hook yet,...as I said, those WILL go on in the future and I will be giving you a holler when it happens.
Nice assembly and detail work...
-REX High Performance-
Old 12-28-2017, 11:48 PM   #13
miker98038
miker98038's Avatar
330 tq. T-5. You driving. Might find some spare axles now. Go a whole 1/2 bubble off, like me.
I’m really liking the whole deal, especially the paint on the motor.
miker98038 is offline   Reply With Quote
Old 12-29-2017, 01:59 PM   #14
scicala
scicala's Avatar
Happy to still be on the hook Rowen. Great job !
Sal
Old 12-29-2017, 03:33 PM   #15
KULTULZ
KULTULZ's Avatar
Sal
Sal,
Allow me to go off-topic ... ... again and ask since you are so familiar with the 8V setups.
I am a$$-u-me(ing) all of these were dual plane intakes (for street use). Did you ever come across any progressive linkage designs?
It seems to me that it would make a set much more street-able and hopefully cut down on fuel usage.
Wondering In WV...
Old 12-29-2017, 03:56 PM   #16
Kahuna
Kahuna's Avatar
Kultulz
This may not be a direct comparison, as mine are on a flathead.
I have 2 Holley 1161-2 carbs on my 290 CI flathead. They are
linked directly and are run on a single plane manifold, They are
really good as far as performance & mileage, with as much as
20+ MPG. I do have an Overdrive, car is a 32 Tudor sedan.
Best
Jim
Old 12-29-2017, 09:34 PM   #17
scicala
scicala's Avatar
KULTULZ,
Ford did it with direct linkage (both open at the same time) at first in '56 and '57 with dual plane manifolds. Later on (427's) they did it progressive with dual plane manifolds. I guess you can assume either works. Also the single plane setup Kanuna mentioned with direct linkage seems to work very well. If I had a preference, I would say direct linkage may offer better air/fuel distribution overall. Just my thoughts.
Sal
Old 12-30-2017, 01:39 AM   #18
KULTULZ
KULTULZ's Avatar
Originally Posted by Kahuna View Post
Kultulz
Best
Jim
THANX for that Jim...
No problem with a single plane intake in cold weather? That's great!
KULTULZ,
Sal
Yeah, FORD went with progressive linkage in later years on multi-carb. I had a 67 GT 500 and a couple of TRI-POWER sets.
What I am trying to get at is street-ability using multi-carbs on the street (other than hot Saturday Night ).
Let's use the 57 312 8V 270HP for instance. This was released for the street (the 285HP meant for track use).
Cruising would have been much easier and cheaper (IMO) with only the primaries of the primary carb being used and the secondary carb primaries cutting in wherever you adjust it. The secondaries of both carbs would come in on demand.
I am just surprised that no one has designed a retro kit.
Old 12-30-2017, 01:56 PM   #19
rowens55
rowens55's Avatar
Has anyone ever put a pusher fan on a 55? If so, how do you like it? A part number?? There are many on the internet, too many. Any help would be greatly appreciated.
Old 12-30-2017, 04:43 PM   #20
KULTULZ
KULTULZ's Avatar
Question Re: My new Y-block
You mean an electric radiator cooling fan(s)?
The pusher style will impede air flow through the radiator. You need one to pull with a full fan shroud (MARK VIII - TAURUS take-off) (IMO).
Plenty of info on the net describing retro-fits.
Your new install getting hot?
