11-08-2014, 09:07 PM | #21 |
Re: licence plate refinish
I've had good luck with Duane Wells in Michigan. He advertises in the V-8 Times. Make sure you send him plates that are nice and straight. Reasonable prices and good turn around time.
11-08-2014, 10:24 PM | #22 | |
On the other hand, I've used a 'plate guy' in Bakersfield (can't remember name), that I would have trouble recommending, if you really want quality. This guy is not a good body-man - the plate came back 'pretty good', but not perfectly straight. His paint work is good. But, the thing that turned me off - he clear-coated the plate. It does not look anything like what it was originally. On the plus side, he is very quick - no more than a week. I would use him again, but understand the work is a little less than perfect. And, I would ask for no clear-coat. |
11-09-2014, 08:21 AM | #23 |
I used these gus and they did a fabulous job. Except now the plate looks brand new and teh truck looks like it is 70+ years old. http://www.restoreatag.com/index.html
GA was the first state to use reflectorized paint. The peach reflects. The year following GA stopped using that very expensive process and didn't start again until the 80's. Before: After: |
11-10-2014, 01:27 PM | #24 | |
11-10-2014, 06:43 PM | #25 |
I had a 1942 New York redone but took a picture before repair and used that to register. Have since went back to regular plates because of limitations on driving. I like to go driving on Sundays and not the shows.
11-10-2014, 10:45 PM | #26 |
Excellent work, fair price and quick turnaround. www.OLDPL8S.com Chris W. |
11-10-2014, 11:05 PM | #27 | |
11-11-2014, 07:14 AM | #28 |
www.OLDPL8S.com They only do California plates.
11-12-2014, 06:31 AM | #29 | |
I am just going to put this down to maybe selecting their expedited service, I don't know. When I called Darryls they did explain I could either get it done at the regular price and it would be ready 'whenever it was ready' OR I could pay an extra $25 for expedited service where they actually tell you when you pay what date the plate will ship to you. I opted for that and they shipped as promised, 3-4 weeks later. |
11-18-2014, 02:44 PM | #30 |
1. Glass bead or wire brush the plate down to bare metal.
2. Primer with Rust-oleum. 3. Spray the entire plate with lacquer that matches the number colors. Let cure for about a week. 4. Spray the plate with enamel that matches the background color. 5. Wait for the paint to flash dry and wipe off the numbers with a semi-damp rag soaked in mineral spirits. 6. Have several rags handy, as each letter will take a clean rag. Gently wipe through the enamel on the raised number to the lacquer undercoat. 7. Let the plate dry for several days and clear coat if desired, usually satin enamel, lightly. Worked for me on two 1932 NM plates. |
11-18-2014, 02:59 PM | #31 |
Oh come on guys - just paint the back of the plate - let it dry real good get out a can of One Shot color of the numbers - pull out a good artist paint brush - drink down a couple shots of your favorite hard stuff to steady your hand and paint the numbers - I've several and got a bunch of compliements about my work - trust me it's not that hard if I can do it. Once you done one you will be real proud of the results.
