Old 09-26-2019, 11:04 PM   #1
Lefthander1930
Lefthander1930's Avatar
Default Gas additive
Do I need to run some kind Lead/fuel additive in My A ? Is there a certain brand to look for ?
Lefthander1930
Lefthander1930 is offline   Reply With Quote
Old 09-26-2019, 11:15 PM   #2
40 Deluxe
Default Re: Gas additive
The gas available when Model A's were new or near new did not have lead so it's not needed now.
Old 09-26-2019, 11:38 PM   #3
TerryH
TerryH's Avatar
Many add Marvel Mystery Oil to each tank of gas....long history of it being used....4 oz per 10 gallons....
TerryH is offline   Reply With Quote
Old 09-27-2019, 12:44 AM   #4
Synchro909
Synchro909's Avatar
I add a lead substiute every fill. 1ml per litre. For thoise not so familiar with the metric system, that's 1 in 1,000. It acts as an upper cylinder lubricant AND a lead replacement. I'm sure there will be something similar available over there. The one I use is Australian formulated and made. (Flashlube)
Old 09-27-2019, 05:45 AM   #5
Patrick L.
Patrick L.'s Avatar
Nothing needed. But a little ATF doesn't hurt.
Old 09-27-2019, 06:57 AM   #6
updraught
updraught's Avatar
http://www.todayifoundout.com/index....d-to-gasoline/
With compression of 4.2:1, I doubt there is anything to worry about.
"This didn’t seem to faze Midley, who himself came down with lead poisoning during the planning phase. While recovering in Miami, Midgley wrote to an oil industry engineer that public poisoning was “almost impossible, as no one will repeatedly get their hands covered in gasoline containing lead…”"
This has never happened to you, has it .... ?
updraught is offline   Reply With Quote
Old 09-27-2019, 08:23 AM   #7
Redbird
Redbird's Avatar
We have ethynol free gas at our Quick Trip gas stations and some Walmarts here in TX!
Redbird is offline   Reply With Quote
Old 09-27-2019, 08:40 AM   #8
rotorwrench
rotorwrench's Avatar
The model A was made to run some pretty crappy fuel back in that time frame. Tetra ethyl lead wasn't added until higher compression cars became available. All the additives are is a top end lube to increase the life of the valve train. Most modern unleaded fuels already have additive for valves in them. If an engine already has hardened valve seats then a top end lube is really not all that necessary. MMO certainly won't hurt though as long as a person puts in no more than is recommended.
Old 09-27-2019, 12:32 PM   #9
1931 flamingo
1931 flamingo's Avatar
Lead additive a waste of money as is ZDDP. Use StaBil or SeaFoam and glug glug glug of MMO or ATF. JMO
Paul in CT
Old 09-27-2019, 01:35 PM   #10
Werner
Werner's Avatar
ATF is not a good idea! ATF Oil contains many additives (friction improvement, high pressure sulfurization, no antioxidant, etc.) which are not suitable for ashless combustion. ATF is an oil for use outside of internal combustion engines.
If no special top oil (f.ex. MMO), then use 0.5% synthetic two-stroke oil.
All gear oils burn with a lot of carbon residue!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is online now   Reply With Quote
Old 09-27-2019, 01:37 PM   #11
Forddan
Paul in CT
Second posting I read with your glug glug glug of MMO.....LOL
Can you please tell me the meaning.
Thanks !!!
Forddan is offline   Reply With Quote
Old 09-27-2019, 01:55 PM   #12
Patrick L.
Patrick L.'s Avatar
I guess engines over here did not get that memo. Its worked since it was discovered. Works good on valve guides and keeps carbon loosened up. Also seems to keep carburetors from varnishing. Been using it personally for 6 decades, guess I'll keep on.
Old 09-27-2019, 06:11 PM   #13
1931 flamingo
Forddan: I never carried a measuring cup with me. Most say 4 oz of MMO to 10 gal
of gas. I just tip the bottle and : glug glug glug. More than 4 oz not going to hurt anything.
Paul
Old 09-27-2019, 08:22 PM   #14
Forddan
Paul
Thank you Paul !!!
Nice to know from your experience that more than 4 oz will not hurt. As I never wait to have the tank empty it is not easy to add the correct amount. So I was adding "what I though mathematically was correct" but for sure it is more than the 4 oz / 10 G.
I only had the car since January. My first year. So still learning.
Thanks again!!!
Old 09-27-2019, 11:52 PM   #15
eagle
eagle's Avatar
I second that. I've been using ATF in small engines for a long time. Briggs two cylinder engines have a habit of sticking valves. ATF in the gas will solve the issue.
Old 09-28-2019, 05:28 AM   #16
Patrick L.
Patrick L.'s Avatar
At the other end of the spectrum, early hydraulic lifters were famous for sticking/rattling. A cure was an oil drain and a fill with ATF, run the engine until they started working again. Change the oil and give it back to the owner.
Old 09-28-2019, 08:03 AM   #17
rotorwrench
Posts about gas and oil are always interesting in there results. If it was good enough for Grandpa? OK?
Old 09-28-2019, 08:08 AM   #18
Patrick L.
Patrick L.'s Avatar
Some things change, some don't. Some of the old stuff still works.
